shellux
(Shellux)
1
I try to integrate the value the energie consumed of the house with a téléinfo module.
I create a rest sensor, who give me in json, 2 value:
HCHC
HCHP
For exemple, the result of the value HCHC is 50131222, but i need to only keep the 5 first digit (or a least trunk the 3 last digits) (50131).
Do someone could help me to this?
finity
2
if the result isn’t string then you need to convert it to a string then extract the value:
{% s = value_json|string %}
{{ s[:5] }}
or if it’s already a string (which is likely) then you can use this to get the first 5 digits:
{{ value_json[:5]}}
I hope that’s what you wanted.
