Need help troubleshooting an automation
Hello friends,
I can not understand the behaviour of the following automation:
- id: garage_stairs_on_if_entered_after_dark
  alias: "Turn on Garage stairs if front door opens after dark"
    - platform: state
      entity_id: binary_sensor.front_door
      to: 'on'
  condition:
    - condition: state
      entity_id: sun.sun
      state: "below_horizon"
    - service: homeassistant.turn_on
      entity_id: switch.garage_stairs
    - delay: 00:05:00
    - service: homeassistant.turn_off
It behaves properly the first time: once the door opens, the lights would turn on.
BUT- if the same door opens once more within the delay of 5 minutes as specified - the light turns off and stay off…
What is happening and how to make sure it stays on and the timer will just restart… what am I missing?
Any ideas are much appreciated.
I have a similar automation. I added an additional condition to check if the light is off. THat way the automation only runs if the door is opened and the light is off.
THere might be a better way but it works for me. I’m still new to HA.
I usually use 2 automations for this.
https://github.com/Data-Monkey/Home-Assistant-Config/blob/master/config/includes/automations/bathroom.yaml
The off automation triggers x minutes after the last motion.
Thank you both very much
I ended up adding another condition like this:
    - platform: state
      to: 'on'
  condition:
    condition: and
    conditions:
      - condition: state
        entity_id: sun.sun
        state: 'below_horizon'
      - condition: state
        state: 'off'
    - delay: 00:05:00
For what it’s worth, you do not need the lines
condition: and
conditions:
when listing multiple and conditions.
Your automation could be simplified a bit as follows:
    - platform: state
      to: 'on'
  condition:
    - condition: state
      entity_id: sun.sun
    - condition: state
      state: 'off'
    - delay: 00:05:00
