Need help troubleshooting
I took a pause from HA because I was taken back by the latency of zwave commands from the web interface. I want to get back into it, but not sure where to start at. My setup is a Synology DiskStation with an Aeon Zwave USB. I was going to use my odroid if any one thought that might help. Any other suggestions?
I use a Synology server and the Aeon Zwave usb and the commands are almost instant. It could be a defective Zwave usb, interference or something else but since it’s local it should be pretty instant.
Opps. Sorry. I have a Aeotec Gen5 Zwave Plus USB
for Synology, try this: Hass.io on Synology DSM (native package)
Then setup z-wave as an addon and specify where your stick is located…
What makes that special compared to the he docker setup?
hass.io is a combo of a lite linux OS, hass doc…
https://www.reddit.com/r/homeassistant/comments/cb25kb/hassio_as_a_synology_dsm_package/etdq7qd?utm_medium=android_app&utm_source=share
hello,
I followed your guide but i can’t find Hass.io in home assistant,
but i can find the container running
any idea?
