Need Help - trying to design a Pilight.light module to allow for dimmable pilight devices
Hi! I am new to Home assistant, coming from FHEM. I am not really a programmer, but I stumbled across the problem that I want to dimm my lamp using pilight (it is an intertecho dimmer which I got working with “kaku_dimmer”, and it works fine in pilight). Unfortunalty there is no pilight light module, only the switch. So I started writing one up… For one it is a garstly hybrid of light and switch, second there are still some unused remnants of the light class, but anyhow, I hoped I might get it to work, but at the moment the system has stopped complaining about my module, but now started complaining about pilight_switch. Which is not really used in my config right now. Maybe someone has an idea where I am going wrong?
That is the code of my pilightli.py
pilight light platform that implements lights.
For more details about this platform, please refer to the documentation
https://home-assistant.io
import logging
import homeassistant.helpers.config_validation as cv
import homeassistant.components.pilight as pilight
import voluptuous as vol
from homeassistant.components.switch import (SwitchDevice, PLATFORM_SCHEMA)
from homeassistant.const import (CONF_NAME, CONF_ID, CONF_SWITCHES, CONF_STATE)
from homeassistant.components.light import (
    ATTR_BRIGHTNESS, ATTR_COLOR_TEMP, ATTR_RGB_COLOR, ATTR_WHITE_VALUE,
    ATTR_XY_COLOR, SUPPORT_BRIGHTNESS, SUPPORT_COLOR_TEMP, SUPPORT_RGB_COLOR,
    SUPPORT_WHITE_VALUE, Light)
LIGHT_COLORS = [
    [237, 224, 33],
    [255, 63, 111],
LIGHT_TEMPS = [240, 380]
SUPPORT_PILIGHTLI = (SUPPORT_BRIGHTNESS | SUPPORT_COLOR_TEMP | SUPPORT_RGB_COLOR |
                SUPPORT_WHITE_VALUE)
_LOGGER = logging.getLogger(__name__)
CONF_BRIGHTNESS = 'brightness'
CONF_OFF_CODE = 'off'
CONF_SYSTEMCODE = 'systemcode'
CONF_UNIT = 'unit'
DEPENDENCIES = ['pilight']
COMMAND_SCHEMA = pilight.RF_CODE_SCHEMA.extend({
    vol.Required('brightness'): cv.positive_int,
    vol.Optional('off'): cv.positive_int,
    vol.Optional(CONF_UNIT): cv.string,
    vol.Optional(CONF_ID): cv.positive_int,
    vol.Optional(CONF_STATE): cv.string,
    vol.Optional(CONF_SYSTEMCODE): cv.string,
SWITCHES_SCHEMA = vol.Schema({
    vol.Required(CONF_BRIGHTNESS): COMMAND_SCHEMA,
    vol.Optional(CONF_OFF_CODE): COMMAND_SCHEMA,
PLATFORM_SCHEMA = PLATFORM_SCHEMA.extend({
    vol.Required(CONF_SWITCHES):
        vol.Schema({cv.string: SWITCHES_SCHEMA}),
def setup_platform(hass, config, add_devices_callback, add_devices, discovery_info=None):
    """Set up the Pilight platform."""
    switches = config.get(CONF_SWITCHES)
    devices = []
    for dev_name, properties in switches.items():
        devices.append(
            PilightLight(
                hass,
                properties.get(CONF_NAME, dev_name),
                properties.get(CONF_BRIGHTNESS),
                properties.get(CONF_OFF_CODE),
    add_devices(devices)
class PilightLight(Light):
    """Represenation of a Pilight light."""
    def __init__(
            self, name, state, rgb=None, ct=None, brightness=15,
            xy_color=(.5, .5), white=200):
        """Initialize the light."""
        self._hass = hass
        self._name = name
        self._state = state
        self._rgb = rgb
        self._ct = ct or random.choice(LIGHT_TEMPS)
        self._brightness = brightness
        self._xy_color = xy_color
        self._white = white
    @property
    def should_poll(self):
        """No polling needed for a demo light."""
        return False
    @property
    def name(self):
        """Return the name of the light if any."""
        return self._name
    @property
    def brightness(self):
        """Return the brightness of this light between 0..255."""
        return self._brightness
    @property
    def xy_color(self):
        """Return the XY color value [float, float]."""
        return self._xy_color
    @property
    def rgb_color(self):
        """Return the RBG color value."""
        return self._rgb
    @property
    def color_temp(self):
        """Return the CT color temperature."""
        return self._ct
    @property
    def white_value(self):
        """Return the white value of this light between 0..255."""
        return self._white
    @property
    def is_on(self):
        """Return true if light is on."""
        return self._state
    @property
    def supported_features(self):
        """Flag supported features."""
        return SUPPORT_PILIGHTLI
    def turn_on(self, **kwargs):
        """Turn the light on."""
        self._state = True
        if ATTR_RGB_COLOR in kwargs:
        self._state = True
            self._rgb = kwargs[ATTR_RGB_COLOR]
        if ATTR_COLOR_TEMP in kwargs:
            self._ct = kwargs[ATTR_COLOR_TEMP]
        if ATTR_BRIGHTNESS in kwargs:
            self._brightness = kwargs[ATTR_BRIGHTNESS]
            self._hass_service.call(pilight.DOMAIN, pilight.SERVICE_NAME,
                                    self._brightness, blocking=True
        if ATTR_XY_COLOR in kwargs:
            self._xy_color = kwargs[ATTR_XY_COLOR]
        if ATTR_WHITE_VALUE in kwargs:
            self._white = kwargs[ATTR_WHITE_VALUE]
        self.update_ha_state()
    def turn_off(self, **kwargs):
        """Turn the light off."""
        """Turn the switch on by calling pilight.send service with off code."""
        self._hass.services.call(pilight.DOMAIN, pilight.SERVICE_NAME,
                                 self._code_off, blocking=True)
        self._state = False
oh i have a kaku_dimmer would love to see this working :slight_smile:. Did you upgrade to the latest Home-Assistant version? Because there is a problem with pilight not working in the latest version. Maybe that explains the complaining about your pilight switch.
I know, and I do have a similar problem, but I am on 0.32, so that would be the current version, no? At least I can’t get a newer…
So, I managed to get no more warnings with the module, but then again, It really does not mean anything, because for some reason the hass webGUI is not starting if I am calling th emodule. So there is still a bug, and I don’t know what to fix, because the home-assistant.log does not contain any errors… Maybe someone has an idea?
import logging
from homeassistant.components.light import (ATTR_BRIGHTNESS, SUPPORT_BRIGHTNESS, Light)
SUPPORT_PILIGHT = SUPPORT_BRIGHTNESS
CONF_ON_CODE = 'on'
CONF_UNIT = 'unit'
    vol.Optional('brightness'): cv.positive_int,
    vol.Required('off'): cv.positive_int,
    vol.Required('on'): cv.positive_int,
    vol.Optional(CONF_UNIT): cv.positive_int,
    vol.Optional(CONF_SYSTEMCODE): cv.positive_int,
    vol.Optional(CONF_BRIGHTNESS): COMMAND_SCHEMA,
    vol.Required(CONF_ON_CODE): COMMAND_SCHEMA,
    vol.Required(CONF_OFF_CODE): COMMAND_SCHEMA,
    devices = []
        devices.append(
            PilightLight(
                hass,
                properties.get(CONF_ON_CODE),
    def __init__(
            self, name, state, brightness=None):
        self._hass = hass
        self._name = name
        self._state = state
    @property
        return False
    @property
    def name(self):
        return self._name
    @property
    @property
    def is_on(self):
        return self._state
    @property
        self._state = True
            self._brightness = kwargs(ATTR_BRIGHTNESS)
        else:
                                 self._code_on, blocking=True)
            self._state = True
        self._state = False
If you have something just open a pull request. Code review is not a strength of this forum, but of github.
did you ever get this to work? I’m interested in dimming as well with Pilight.
No, sorry. But I stopped working on it eventually, because I built a nanoCUL…
