type: custom:button-card
color_type: card
entity: switch.shellyGaragentor
state:
- value: "on"
color: green
icon: mdi:garage-open
styles:
card: null
- operator: default
color: green
- value: "off"
name: Garagentor geschlossen
color: red
icon: mdi:garage
styles:
card: null
- operator: default
color: green
I originally cobbled together the above code to control my garage door.
However, my Shelly is only a pulse generator.
In other words: I press the button and it gives the impulse = door moves up/down/stops
However, this also means that it switches on and then switches off again immediately.
Technically no problem, but I would like to implement it visually as described in the code above.
As a layman, however, it is quite difficult for me.
Instead of reactively changing the status of the button, would it simply have to change its appearance every time it is pressed?
I am using a Shelly Mini Gen 3.
I hope that someone can help me with this.
Edit:
Window contacts will be added to the garage later.
It may then be possible to get a better idea of the status.
Perhaps someone can provide me with two code snippets that cover both options.
