I have a no-ip address set up to connect to my ha which is also not https, can you please give a little more details on how you changed the link?
I also use a no-ip address.
on fullfilment you will inform http://YOUR_NAME.ddns.net:8123/api/apiai?api_password=YOUR_PASSWORD
header:
Key = x-ha-access
Value = YOUR_PASSWORD
From this point if your intent script is set on home assistant configuration and api.ai intents are set you should be able to ask questions and receive the answers from home assistant api.
Please note that SSL (https) is required for Actions on Google integration (e.g. google home)
Hi Guys Can any one help me on the following!!
When i’m hitting my home assistant URL something like https://myhome.duckdns.org/api/dialogflow?api_password=HA_PASSWORD
I’m getting error 404
and my DialogFlow response is also showing me 404 error obviously because it could’nt find the URL, any suggestion ?
“status”: {
“code”: 206,
“errorType”: “partial_content”,
“errorDetails”: “Webhook call failed. Error: 404 Not Found”,
“webhookTimedOut”: false
Stupid me Did’nt included the line dialogflow: line in configurations.yaml file
Added it and it’s giving 405
