I’m trying to do an automation and could use some help.
I want to do the following:
rule 1
trigger: DOOR open received or MOTION active received
event: turn on light, start timer (set countdown timer = 10 minutes)
rule 2
trigger: timer expires
event: turn off light
DOOR and MOTION are both mqtt binary sensors.
So I’d like the light to turn on and the timer to be set to 10 minutes whenever the mqtt on payload is received for either the door or the motion detector. When the timer expires, the light goes off. I don’t want to use the off payload for either the door or the motion detector.
Most of what you need is in the documentation here:
The other piece of information you need is that you can have multiple trigger items, and when any one of them is triggered, the automation is activated.
Thanks for the replies. I’d seen the example and tried this:
# BASEMENT HALLWAY LIGHT
- action:
- alias: ''
entity_id: switch.bsmt_hallway_scene
service: switch.turn_on
alias: Turn on basement hallway light when there is movement
- entity_id: binary_sensor.status_bsmt_hallway_motion
platform: state
to: 'on'
- entity_id: binary_sensor.w800_device_2
platform: state
to: 'on'
- action:
- data:
service: switch.turn_off
alias: Turn off basement hallway light 10 minutes after last movement
for:
minutes: 10
platform: state
to: 'off'
for:
minutes: 10
platform: state
to: 'off'
It doesn’t work the way I want it to. It relies on off states and the timer doesn’t seem to work correctly. I’m just starting and think I’m missing some basic information that I haven’t found on the site.
Is there a way to create a real timer? I think the 2nd rule above turns the light off if either sensor has been in the off state for 10 minutes. I want to turn the light off if the on payload hasn’t bee received for 10 minutes for either sensor.
Is there an alternative for creating automation rules in a conventional programming language?
You need to add 2 conditions for binary_sensor.status_bsmt_hallway_motion and binary_sensor.w800_device_2 to ensure both are off for 10 minutes. Without the condition, it’s functioning as an OR. The condition can make it function like AND. Check out https://home-assistant.io/docs/automation/condition/ for more details.
Thanks for that example, and apologies for pulling up an old thread. I’m just starting out with hass and I’m trying to implement your resettable motion sensor timer example. I get the following message “WARNING (MainThread) [homeassistant.core] Unable to find service script/turn_on” in relation to the script.
I noted that your example uses ‘execute_service’ and ‘service_data’ whereas https://home-assistant.io/docs/scripts/ just uses ‘execute’ and ‘data’. Are they equivalent, or is this example out of date with respect to current syntax, or something else? I don’t see ‘execute_service’ or ‘service_data’ referenced on https://home-assistant.io/docs/scripts/service-calls/ either so I’m a little stumped.
