Need help with ceiling fan
hello all,
I have a SUNMORY ceiling fan from amazon and I want to integrate it to ESPHome.
the remote is RF and the FCC ID is 2A8BN-F29,
I have the RAW data and an esp32 and CC1101 module
I have a code from dbuezas working but as a push button and I will like to act as switch for the light
also I will like to change my code so I can adjust the fan speed.
# light on/off
button:
    on_press:
      - lambda: get_cc1101(transciver).beginTransmission();
      - remote_transmitter.transmit_raw:
          # prettier-ignore
          code: [729, -247, 242, -732, 745, -228, 736, -233, 241, -765, 225, -765, 719, -261, 704, -256, 236, -741, 256, -735, 249, -760, 222, -755, 246, -751, 246, -750, 220, -772, 220, -772, 220, -773, 221, -747, 247, -746, 248, -743, 245, -744, 741,
                 -236, 261, -723, 242, -762, 244, -738, 244, -739, 245, -764, 716, -261, 235, -749, 714, -256, 711, -246, 729, -247, 218]
          repeat:
            times: 3
            wait_time: 4.733ms
      - lambda: get_cc1101(transciver).endTransmission();
that snip is what I have as light ON/OFF I have the same code for my speeds but cant use the light card or fan template
thanks
Miguel
Why so? Explain better.
Do you have separate codes for the fan and the light?
Wouldn’t it work with fan like this? (use the code to turn on fan)
 fan:
    on_turn_on:
          # prettier-ignore
          repeat:
            times: 3
            wait_time: 4.733ms
as per light card, I don’t see my light device as switch only as push button.
i dont kow how to set it as a switch or light
as per fan goes, this is my code.
output:
    type: float
    write_action:
      - if:
          condition:
            lambda: return ((state == 0));
          then:
            # action for off
          #  - lambda: get_cc1101(transciver).beginTransmission();
                code: [767, -210, 263, -725, 742, -226, 757, -222, 244, -736, 271, -732, 744, -234, 747, -212, 265, -723, 264, -723, 289, -717, 259, -738, 248, -737, 247, -755, 247, -727, 271, -723, 248, -746, 247, -744, 243, -744, 243, -743, 739, -234, 264,
                 -726, 735, -234, 747, -223, 255, -741, 752, -233, 252, -721, 271, -720, 742, -236, 753, -210, 266, -726, 743, -222, 246]
                repeat:
                  times: 3
                  wait_time: 4.733ms
          #  - lambda: get_cc1101(transciver).endTransmission();
      - if:
          condition:
            lambda: return ((state > 0) && (state < 0.4));
          then:
            # action for speed 1
                repeat: 5
      - if:
          condition:
            lambda: return ((state > 0.4) && (state < 0.7));
          then:
            # action for speed 2
                repeat: 5
      - if:
          condition:
            lambda: return ((state > 0.7));
          then:
            # action for speed 3
                repeat: 5
fan:
  - platform: speed
    output: ceiling_fan
    speed_count: 3
but I only see is as a slider and not as a 3 speed fan.
thanks,
Miguel
The way I did it was by creating a bunch of switches for code I wanted to send (on, off, high, medium, low):
switch:
########## - Dining Room Fan Switches - ##########
    name: "Dining Room Fan On"
    turn_on_action:
          code: [722, -699, 302, -746, 310, -748, 302, -732, 323, -730, 344, -693, 358, -349, 692, -359, 671, -383, 681, -724, 308, -721, 359, -378, 670, -384, 655, -351, 706, -344, 716, -356, 669, -384, 676, -741, 306, -720, 333, -700, 360, -711, 322, -737, 344, -693, 307, -396, 672]
          repeat:
            times: 10
            wait_time: 10ms
then creating a template fan that called those switches:
######### - Only Fans - ##########
    name: "Dining Room Fan"
    speed_count: 3
    on_turn_on:
      - switch.turn_on: drf_speed_hi
      #- lambda: 'id(DR_Fan).speed = 3;'
    on_turn_off:
      - switch.turn_on: drf_speed_off
      #- switch.turn_off: DR_Light
    on_speed_set:
      then:
        - if:
            condition:
              lambda: 'return id(DR_Fan).speed == 3;'
            then:
        - if:
            condition:
              lambda: 'return id(DR_Fan).speed == 2;'
            then:
              - switch.turn_on: drf_speed_med
        - if:
            condition:
              lambda: 'return id(DR_Fan).speed == 1;'
            then:
              - switch.turn_on: drf_speed_lo
This is for a couple fans that are 309mhz but I have two more that use the same remote yours does. I’m working on setting those up too.
My full code is here:
Could you share your raw data for this remote? I’ve captured the fan on/off toggle but I’m having trouble accurately capturing raw data for any of the other buttons.
attached a a file with all my raw data.
I think that the codes are unique to each fans, I have 2 and these codes wont do anything to my other fan
FAN ON/OFF:
  1121, -360, 356, -1096, 386, -1090, 365, -1091, 1096, -388, 1089, -350, 1106, -368, 369, -1101, 378, -1101, 363, -1087, 371,
 -1115, 1100, -373, 346, -1098, 1091, -369, 369, -1105, 373, -1097, 1091, -368, 1117, -362, 1078, -355, 1113, -369, 1099,
 -380, 1071, -388, 1087, -372, 363, -1115, 344, -1115, 1099, -365, 1087, -370, 1092, -419, 1099, -362, 361, -1099, 1090,
 -369, 371, -1099, 380
FAN SPEED 1:
  1112, -358, 391, -1093, 361, -1105, 389, -1100, 1105, -350, 1090, -393, 1095, -361, 399, -1096, 368, -1107, 365, -1099, 382,
 -1096, 1091, -394, 342, -1096, 1110, -373, 388, -1091, 369, -1122, 1085, -371, 1090, -399, 1095, -366, 1084, -398, 363,
 -1090, 1095, -362, 1126, -349, 390, -1083, 1115, -380, 1097, -364, 1112, -369, 366, -1113, 1122, -378, 362, -1080, 1116,
 -371, 1094, -363, 384
FAN SPEED 2:
  1094, -361, 403, -1094, 363, -1115, 368, -1118, 1089, -367, 1115, -384, 1106, -350, 388, -1112, 368, -1100, 383, -1100, 389,
 -1089, 1094, -386, 383, -1097, 1091, -395, 368, -1094, 386, -1130, 1095, -360, 1101, -354, 1142, -365, 1095, -385, 378,
 -1103, 1114, -345, 1118, -388, 358, -1101, 386, -1116, 1093, -363, 382, -1101, 1116, -397, 399, -1095, 1114, -351, 393,
 -1093, 365, -1108, 398
FAN SPEED 3:
  1093, -386, 382, -1096, 390, -1092, 367, -1102, 1105, -362, 1112, -342, 1118, -377, 373, -1092, 386, -1085, 393, -1088, 371,
 -1094, 1117, -343, 393, -1090, 1118, -363, 360, -1097, 389, -1093, 1094, -386, 1109, -352, 1113, -336, 1140, -361, 354,
 -1094, 1134, -347, 365, -1097, 1111, -372, 1104, -376, 1094, -387, 361, -1101, 1093, -416, 1100, -363, 1091, -396, 363,
 -1091, 1094, -387, 381,
FAN SPEED 4:
  1115, -389, 358, -1098, 364, -1138, 345, -1122, 1089, -364, 1139, -362, 1106, -362, 386, -1111, 363, -1084, 392, -1094, 384,
 -1083, 1117, -383, 354, -1120, 1089, -398, 346, -1118, 388, -1106, 1090, -361, 1127, -379, 1086, -375, 1092, -414,  362,
 -1105, 1091, -373, 368, -1120, 1091, -394, 364, -1092, 1121, -389, 1087, -367, 362, -1161, 355, -1120, 1090, -370, 393,
 -1095, 359, -1100, 390
FAN SPEED 5:
  1076, -419, 308, -1159, 344, -1150, 329, -1128, 1102, -380, 1073, -392, 1109, -369, 342, -1151, 354, -1129, 335, -1112, 391,
 -1095, 1112, -369, 389, -1084, 1095, -389, 384, -1102, 351, -1108, 1120, -383, 1085, -365, 1116, -385, 1103, -362, 361,
 -1130, 1091, -386, 351, -1118, 364, -1109, 1093, -409, 1085, -367, 364, -1114, 379, -1149, 1091, -361, 1127, -372, 1090,
 -370, 1120, -361, 383
LIGHT ON/OFF:
  1072, -382, 374, -1095, 385, -1082, 365, -1108, 1095, -382, 1086, -368, 1092, -377, 347, -1119, 360, -1105, 362, -1115, 343,
 -1099, 1107, -372, 365, -1088, 1095, -386, 356, -1118, 363, -1111, 1092, -359, 1100, -388, 1093, -341, 1090, -395, 1099,
 -358, 382, -1099, 1091, -372, 340, -1139, 1078, -388, 1089, -368, 362, -1115, 1069, -413, 1110, -369, 362, -1085, 392,
 -1095, 358, -1098, 363
LED +:
  1085, -367, 366, -1102, 376, -1095, 359, -1109, 1098, -353, 1095, -387, 1086, -373, 358, -1111, 369, -1101, 353, -1119, 357,
 -1109, 1071, -381, 371, -1095, 1084, -366, 389, -1091, 354, -1121, 1091, -368, 1094, -359, 1102, -379, 1084, -368, 1091,
 -382, 374, -1094, 1089, -369, 370, -1089, 370, -1119, 1089, -367, 366, -1115, 354, -1145, 350, -1113, 369, -1093, 360,
 -1101, 1116, -371, 340
LED -:
  1090, -361, 380, -1100, 356, -1110, 373, -1098, 1077, -363, 1089, -370, 1116, -347, 392, -1094, 361, -1100, 388, -1091, 369,
 -1070, 1109, -373, 364, -1091, 1094, -383, 354, -1095, 364, -1111, 1099, -356, 1097, -360, 1108, -373, 1088, -374, 1095,
 -385, 359, -1098, 1089, -373, 1095, -364, 382, -1098, 363, -1090, 1096, -382, 374, -1120, 381, -1088, 367, -1097, 1108,
 -362, 365, -1106, 364
K:
 1100, -379, 359, -1106, 374, -1106, 350, -1115, 1085, -395, 1071, -381, 1073, -413, 335, -1128, 361, -1115, 342, -1123,
 356, -1098, 1089, -373, 366, -1100, 1106, -370, 362, -1115, 369, -1128, 1081, -371, 1091, -393, 1095, -361, 1107, -400,
 1088, -372, 1094, -386, 358, -1098, 362, -1112, 369, -1124, 357, -1124, 360, -1090, 1094, -435, 335, -1129, 361, -1085,
 1117, -359, 354, -1122, 357
DIM:
 1108, -350, 385, -1107, 342, -1114, 370, -1094, 1089, -370, 1088, -373, 1095, -361, 383, -1101, 362, -1114, 363, -1104,
 347, -1119, 1089, -369, 362, -1090, 1094, -389, 353, -1096, 359, -1134, 1097, -358, 1100, -358, 1083, -397, 1090, -370,
 1095, -387, 1085, -350, 387, -1088, 386, -1090, 1094, -386, 1087, -349, 1114, -369, 1094, -410, 358, -1103, 1089, -370,
 369, -1107, 350, -1122, 363
BRIGHT:
 1068, -383, 351, -1121, 342, -1108, 370, -1119, 1057, -386, 1087, -395, 1064, -376, 370, -1119, 334, -1134, 357, -1114,
 344, -1100, 1080, -412, 336, -1108, 1063, -397, 344, -1121, 357, -1124, 1068, -403, 1071, -386, 1083, -373, 1065, -393,
 1071, -408, 352, -1094, 1084, -392, 1069, -382, 1074, -412, 1087, -369, 1070, -398, 346, -1145, 366, -1108, 1069, -383,
 1078, -391, 346, -1104, 345
ALL ON/OFF:
 1076, -383, 355, -1109, 349, -1138, 345, -1095, 1114, -344, 1116, -379, 1089, -361, 380, -1099, 355, -1112, 369, -1097,
 356, -1121, 1091, -372, 369, -1094, 1086, -395, 365, -1092, 369, -1119, 1087, -366, 1091, -381, 1102, -362, 1087, -397,
 1099, -353, 1096, -362, 1108, -371, 365, -1085, 1118, -384, 1082, -365, 365, -1116, 1095, -387, 386, -1104, 1092, -352,
 369, -1119, 360, -1102, 367
F/R:
 1072, -380, 349, -1125, 357, -1106, 361, -1114, 1067, -385, 1080, -376, 1083, -393, 341, -1126, 354, -1120, 362, -1110,
 345, -1114, 1073, -385, 358, -1100, 1081, -394, 343, -1123, 355, -1124, 1070, -371, 1073, -408, 1059, -376, 1085, -393,
 369, -1100, 1079, -387, 359, -1103, 341, -1108, 370, -1119, 1085, -368, 350, -1130, 346, -1145, 357, -1109, 1092, -358,
 1073, -413, 1062, -395, 341
Nature:
 1071, -407, 353, -1094, 359, -1107, 342, -1130, 1071, -382, 1086, -369, 1092, -399, 345, -1121, 334, -1129, 361, -1090,
 344, -1127, 1078, -387, 336, -1133, 1086, -374, 343, -1122, 356, -1126, 1062, -395, 1067, -384, 1081, -386, 1063, -422,
 1062, -375, 1070, -411, 332, -1122, 1067, -396, 1069, -410, 331, -1123, 1088, -370, 1070, -457, 334, -1101, 1091, -374,
 1094, -382, 1084, -377, 357
