I have this in my configuration section:
- platform: command_line
switches:
vswitch5:
command_on: curl "http://192.168.0.100:80/password/sw/dim/5/{{ state_attr('light.virtual_hal_hw', 'brightness') | int * 0.4}}"
command_off: curl "http://192.168.0.100:80/password/sw/dim/5/0"
command_state: 'true'
value_template: '{{ state_attr("sensor.hwstatus", "response").switches[0].dimlevel }}'
unique_id: 12345678987654326543245678987671
When I run the line
in the developers toolkit for templates it gives me what I except:
"http://192.168.0.100:80/password/sw/dim/5/40.800000000000004"
But when it accutually sends the command to the host I get an error. The log says:
Logger: homeassistant.components.command_line.switch
Source: components/command_line/switch.py:133
Integration: command_line (documentation, issues)
First occurred: 20:28:31 (1 occurrences)
Last logged: 20:28:31
Command failed: curl "http://192.168.0.100:80/password/sw/dim/5/{{ state_attr('light.virtual_hal_hw', 'brightness') | int * 0.4}}"
which makes it look like
isn’t translated the way I expected. Does that mean this can’t be achieved at this moment or is there yet another way to dim the light. Or do I need more {,",’ or )? I already tried some combinations without success
