I’m trying to install the Home Assistant sensors for Xplora watch from here: https://github.com/Ludy87/xplora_watch. But as a new Home Assistant user I get stuck. Does anyone have experience of using that integration?
I understand for new integrations to be included in Integrations - Home Assistant they have to use the configuration via the webGUI, so I have never really used configuration.yaml. And although I’ve tried to follow the instructions at https://github.com/Ludy87/xplora_watch nothing from Xplora appears anywhere, in order to use in automations.
Using File Editor, my /config/configuration.yaml currently looks like this:
# Loads default set of integrations. Do not remove.
default_config:
# Text to speech
tts:
- platform: google_translate
script: !include scripts.yaml
scene: !include scenes.yaml
xplora_watch:
country_code: "+46"
phonenumber: "07********"
password: "***********"
userlang: "sv-SE"
timezone: "Europe/Stockholm"
child_phonenumber: # optional & ignored if 'watch_id' is set
- "07********"
- "07********"
types: # optional
- "battery"
- "step_day"
- "state"
- "safezone"
- "charging"
- "silents"
- "alarms"
- "dt_watch"
safezones: "show"
scan_interval: 180
tracker_scan_interval: 60
notify:
- platform: xplora_watch
I have restarted after adding this to configuration.yaml. I suppose there must be something wrong with the configuration?
Check under Developer Tools → States and Under Entity Filter type Watch.
If averything works you should get following:
watch_charging
watch_safezone
watch_state
watch_bettery
watch_step_day
watch_xcoin
watch_alarm
watch_silent
I canæt figure out how to get Watch to show Home / Away tough.
Thanks. I realized that the error was that I had the leading 0 in the children’s phone numbers. Removing that and it worked.
Although there are some other issues, like watch trackers not updating and battery level being set to -1. But there is the discussion at Issues · Ludy87/xplora_watch · GitHub too.
Sorry to jump on this but i’m having issues setting this up, i have tried setting it up through the UI but having no luck, I’ve added my details but its coming back as connection failed. I then tried through yaml but i’m getting;
Logger: homeassistant.components.notify
Source: custom_components/xplora_watch/notify.py:24
Integration: Notifications (documentation, issues)
First occurred: 20:06:51 (1 occurrences)
Last logged: 20:06:51
Error setting up platform xplora_watch
Traceback (most recent call last): File “/usr/src/homeassistant/homeassistant/components/notify/legacy.py”, line 71, in async_setup_platform notify_service = await hass.async_add_executor_job( File “/usr/local/lib/python3.10/concurrent/futures/thread.py”, line 58, in run result = self.fn(*self.args, **self.kwargs) File “/config/custom_components/xplora_watch/notify.py”, line 24, in get_service coordinator: XploraDataUpdateCoordinator = hass.data[DOMAIN][(discovery_info or {})[CONF_ENTITY_ID]] KeyError: ‘entity_id’
I just got the X5 Play and installed the integration. Somehow I am only able to see the number of messages. All other entities are unknown. Anybody know how to solve this?
