Hi, found one of your blueprints @Aleks130699 and it works nicely but I would like to change it a bit so that the light does not come on when it is bright in the room. I tried adding an iluminance sensor as a condition to it but Home Assistant does not like my yaml coding
I would love it if you or some other yaml guru could check what the issue is. I suspect it is just the formatting of the code but I struggle to figure it out:
