h, i got my esp32s3 in the mail today but when connecting the wifi, the ufl connector fell off, what can i do? can i use it withou or fix it?
No you can not use it without an antenna.
Are you any good at SMD rework?
If so, then yes you can fix it.
no im not, can i use a a wifi module i connect to it?
cant i use an esp-12f?
No.
Your only option is to purchase a new one and be more careful.
UFL connectors are not made for repeated connection and disconnection. They also do not tolerate any lateral force well. Push straight down or lever straight up only.
