hey,
What code lines should I write in esphome in ha
to use this sensor?
i guess it you can try binary sensor
That would depend on what you want to do with it. See:
And
And
this sensor should act as ultrasonic sensor.
It sends ir and receive it.
I can’t find this sensor in esphome to use their template code.
Oh. It’s only a distance sensor, looks just like an ir transceiver I have. Then the first suggestion by Gijs is correct.
Just hook it up to a pin and see what happpens it should only be on or off
thanks!
got it work
