Once I reboot the host the disk utilization goes back to normal around 70% (I do have some files in the smb share folder), but after couple of hours it climbs back quickly to 100%.
I added these to the configuration.yaml, but it did not help:
Unfortunately --maxdepth=1 isn’t working. I’m running Home assistant OS, maybe that’s why… also du shows only 60GB disk usage out of 110GB, meanwhile HAOS and df are showing 100% disk usage.
➜ / du -hs
du: can’t open ‘./proc/573/task/573/fdinfo’: Permission denied
du: can’t open ‘./proc/573/fdinfo’: Permission denied
66.3G .
Yes on HAOS du is the version supplied by busybox, which is a bit different. For that version, try
du -d 1
If it is filling rapidly and reverts when you restart, it is probably something temporary, like a runaway log file in a container. But it won’t be unused images, as they are only installed when you update docker image.
Yes, exactly. I tried to drill down using du -d 1 yesterday, but du was just not even showing that I’m utilized at 100%. Anyways I found out what was causing it. It was the google drive backup addon, as I forgot to exclude the /share folder (even though I thought I did). After excluding this folder (it contains about 60GB of data), all is working fine!
Thank you for your help and time.
