Yes, thats true. But I want to have 3 speeds, but preconfigured with 32, 64 and 84 percent - and name those to “Low, med and high” for exemple
What is the significance of those specific speed percentages? Is the fan actually capable of discerning between 64% & 67% or 84% & 100%?
if all you had before was low, medium, high then 33% 67% and 100% are those functional equivalents in the config.
It did not have low, medium and high by it self. Its a dimmer and probably used for lights, but i use it for my home ventilation. I made a template fan and made 3 speeds in the code, and the speeds where as writen above, and then I named the speeds “low,mid and high”.
then instead of using percentages then look at using preset modes.
As of this moment I am convinced that you can use presets of low, medium and high then in the preset template set the percentages to what the corresponding percentages should be.
I think it might work.
I guess what I’m not understanding in this conversation is if the switch you guys are using is actually designed as a light dimmer or fan speed controller?
And how does it actually control the physical fan connected to it.
Does the fan have certain speeds (discrete low medium high speeds like is controlled by relays) or does it take variable speed outputs (as in a variable speed motor controller)?
here you have it. I am not using the switch, just the light entity to dim my ventilation / fan. Same as a light but its a fan
I have searched but no luck with finding any exemples to create preset template
Could you post the template fan config as it was that worked before the latest changes?
Hi. I dont have the old setup but I am sure I used this code and changed to my entity name and made 3 speeds instead.
I can’t be sure it will work since I don’t have your devices but this might work based on the code you linked to:
fans:
one1in:
friendly_name: "one1in"
value_template: "{{ states('light.60600011ecfabcab8f89') }}"
percentage_template: >
{% set output = {0:0, 140:33, 200:66, 255:100} %}
{% set idx = state_attr('light.60600011ecfabcab8f89', 'brightness') %}
{{ output[idx] }}
turn_on:
service: homeassistant.turn_on
entity_id: light.60600011ecfabcab8f89
turn_off:
service: homeassistant.turn_off
set_percentage:
data_template:
brightness: >
{% set mapper = {0: 0, 33: 140, 66: 200, 100: 255} %}
{{ mapper[percentage] }}
speed_count: 3
you will need to change it to your entity but try it and see if it works.
That won’t work, your templates are correct but you should edit the post and make the services light.turn_on/off
I figured it either worked before or they knew how to change it to make it work.
it might have been different if they were able to post their actual previously working code.
But at least it gets them started.
Thanks alot for the help! I changed what I should but nothing happens. Here is the old code and new code:
qubino:
friendly_name: "Frånluftsventilation"
value_template: "{{ states('light.qubino_goap_zmnhvdx_flush_dimmer_0_10v_level') }}"
speed_count: 3
percentage_template: "{{ (state_attr('light.qubino_goap_zmnhvdx_flush_dimmer_0_10v_level','brightness') | int /255*100) | int}}"
turn_on:
service: light.turn_on
entity_id: light.qubino_goap_zmnhvdx_flush_dimmer_0_10v_level
turn_off:
service: light.turn_off
set_percentage:
data_template:
brightness_pct: "{{percentage}}"
test_qubino:
friendly_name: "test qubino"
{% set idx = state_attr('light.qubino_goap_zmnhvdx_flush_dimmer_0_10v_level', 'brightness') %}
{{ output[idx] }}
turn_on:
turn_off:
set_percentage:
data_template:
brightness: >
speed_count: 3
When I set the old fan to 66 %, nothing changes with test_qubino…
The only thing I see is trhat I forgot to convert the brightness number (0-255) to percent (0-100).
try this in place of your percentage_template:
{% set idx = ((state_attr('light.qubino_goap_zmnhvdx_flush_dimmer_0_10v_level', 'brightness') | int /255) * 100) | int %}
{{ output[idx] }}
I had to build a test template light but I could control the fan speed from the light and the light brightness from the fan. So I’m pretty sure it works.
If you would like to not have the speed list deprecated I’ve requested that the old speed list options should be kept and I’ve had a suggestion from a dev that if a FR gets enough votes they would implement it.
Here is the FR. Please go there and vote it up.
