Need help with finding a zigbee relay
Need help with find a zigbee relay that can operate my gaz heater. My heater is a Wall-mounted gas boiler with condensing technology - saunier duval Thelia Condens 35-A R1. The relay should know no and nc (normal open and normal close).
Use the search box to find supported relays.
Thank you for the db. Great tool, still I didn’t find something for that. I’m thinking mamy is a better ideea tu use de ebus slot/function of the heating system, then the old normal open contacts. I don’t know
Assuming that you are using it to close the thermostat connection, any relay that looks like your typical diy style will have nc/no connections.
Thank you for the reply. The operatons should be that the relay will tell the gaz boiler when to heat the water for the heating. I found this, sorry, the manual is in Romanian - https://saluscontrols.com/wp-content/uploads/resources/RX10RF/ro/Quick-Guide.pdf
So this is what I want, but I dont what to be limited to one specific brand or gateway. Thank you
