I have installed frigate and my doorbell is up and running and visible in frigate.
I also have a Maginon IPC 250HDC that i want to integrate in frigate.
Unfortunately with no luck.
on this site maginon all the possible url’s are available and in a browser this works: http:// ipadres /videostream.cgi?rate=0&user=&pwd=
In system->integrations → add the camera as an generic mjpeg IP camera. and a in a lovelace card the stream is visible.
configured for stream: http://ip off camera/videostream.cgi
for snapshot: http:// … /snapshot.cgi
The frigide errorlog:
2023-05-26 23:24:24.043756001 [2023-05-27 01:24:24] watchdog.IPC ERROR : The following ffmpeg logs include the last 100 lines prior to exit.
2023-05-26 23:24:24.044233998 [2023-05-27 01:24:24] ffmpeg.IPC.detect ERROR : Option stimeout not found.
2023-05-26 23:24:24.535550834 [2023-05-27 01:24:24] frigate.video ERROR : IPC: Unable to read frames from ffmpeg process.
2023-05-26 23:24:24.537302249 [2023-05-27 01:24:24] frigate.video ERROR : IPC: ffmpeg process is not running. exiting capture thread…
Any help would be appreciated, totally out of clues
Kind regards,
You don’t seem to have added the camera to frigate. But in any event the frigate website is here https://frigate.video/ and their GitHub is the place to go for support.
