comet424
(Comet424)
March 14, 2025, 2:30pm
1
i need help with the !include_dir_merge_named
everything i do it keeps spitting out errors… when you run configuration checker…
ive done 2 different ways 1 with - plaform: template and other without as it complained there was no platforum
ive tried google… and didnt help then i read another splitting up pages HA
and it shows like i guess if you wanna use group: you make a folder group
so i confused in getting it to work
as i wanna do house under packages, and then have basement_light_switchs, group, dehumidifiers… and upstairs_light_switchs
to make it easier to edit later… but its not working right
as i wanna do outside and my shop and maybe couple other break downs so i not having to look in switch.yaml i have or sensor.yaml etc
so below i use the same switchs as a place holder to get this to work
light_switchs.yaml
house_light_switchs:
switch:
dehumidifier_3:
friendly_name: "Dehumidifier 3"
value_template: "{{ is_state('switch.tp_link_smart_plug_04bb_island_light', 'on') }}"
turn_on:
action: switch.turn_on
entity_id: switch.tp_link_smart_plug_04bb_island_light
turn_off:
action: switch.turn_off
dehumidifier_4:
friendly_name: "Dehumidifier 4"
turn_on:
turn_off:
dehumidifier.yaml
house_dehumidifier:
switch:
dehumidifier_3:
turn_on:
turn_off:
dehumidifier_4:
turn_on:
turn_off:
Mikefila
(Mike Fila)
March 14, 2025, 3:37pm
2
Take another look at the documentation. When splitting up entities you do not include the top level key eg house_light_switchs and house_dehumidifier
https://www.home-assistant.io/docs/configuration/splitting_configuration/#top-level-keys
comet424
(Comet424)
March 14, 2025, 3:39pm
3
cuz i wanna do
packages / house
packages /basement
packages/outside
packages/shop
under house folder it be
light_switchs.yaml
sensor.yaml
dehumidifers.yaml
etc
under basement folder
light_switchs.yaml
sensor.yaml
etc
outside folder
etc
shop folder
etc
Mikefila
(Mike Fila)
March 14, 2025, 3:43pm
4
Sorry I missed the packages key. Looking at what you have vs the docs differs.
homeassistant:
packages:
pack_1: !include my_package.yaml
So something like
homeassistant:
packages:
house_dehumidifier: !include dehumidifier.yaml
comet424
(Comet424)
March 14, 2025, 3:45pm
5
ya i read that thats the include
but i trying to do the merge everything
there example is
homeassistant:
packages: !include_dir_merge_named packages/
YAML
and in packages/subsystem1/functionality1.yaml:
subsystem1_functionality1:
input_boolean:
binary_sensor:
automation:
so you gotta add the entire line unless i buggered up my configuration yaml… ill re look
comet424
(Comet424)
March 14, 2025, 3:47pm
6
so my configuration is
homeassistant:
#packages: !include_dir_named ./packages/
packages: !include_dir_merge_named ./packages/
so it should import everything under packages
comet424
(Comet424)
March 14, 2025, 3:49pm
7
so then hte
house_dehumidifier:
is supposed to be file dehumidifier.yaml under the packages/house folder
least thats how i understanding it
Mikefila
(Mike Fila)
8
You still need to remove the top level keys
dehumidifier.yaml
switch:
dehumidifier_3:
turn_on:
turn_off:
dehumidifier_4:
turn_on:
turn_off:
comet424
(Comet424)
March 14, 2025, 3:52pm
9
removing the top line just gives me error
and you can see it says you gotta put the folder name and file name in the config when using merg to merg all the files in folder of package
comet424
(Comet424)
March 14, 2025, 3:56pm
10
so my understand is
homeassistant:
if you had 50 yamls under packages it would import all 50 yamals and you wouldnt need 50 lines of import lines
Mikefila
(Mike Fila)
11
Ok so with that each yaml file gets the top level key, like you have. Each yaml file needs it’s own sub folder. /packages/house_dehumidifier/dehumidifier.yaml
then add to configuration.yaml
homeassistant:
comet424
(Comet424)
March 14, 2025, 3:58pm
12
ya i have that
reason im stuck not work
so i have
/packages/house/dehumidifer.yaml is the file location
then in the yaml first line i have
house_dehumidifier:
to be folder house and file name dehumidifer.yaml but its not liking that theres where i got the orginal errors
then i get the platform error or key errors… thats where i stuck
comet424
(Comet424)
March 14, 2025, 4:00pm
13
so for dehumidifer.yaml i get error
Invalid config for 'switch' at packages/house/dehumidifier.yaml, line 3: required key 'platform' not provided
house_dehumidifier:
switch:
dehumidifier_3:
turn_on:
turn_off:
dehumidifier_4:
turn_on:
turn_off:
comet424
(Comet424)
14
but then i get different error when i add -platform: template so i just been spinning in circles stuck
comet424
(Comet424)
March 14, 2025, 4:03pm
15
so when i add the platform: template i get this error
Setup of package 'house_dehumidifier' failed: Invalid package definition 'house_dehumidifier': expected a dictionary. Package will not be initialized
house_dehumidifier:
switch:
dehumidifier_3:
turn_on:
turn_off:
dehumidifier_4:
turn_on:
turn_off:
so i dont know what i doing wrong i thought i followed the examples best i could understand
Mikefila
(Mike Fila)
March 14, 2025, 4:08pm
16
The format for the template switch should be like this.
switch:
switches:
dehumidifier_3:
turn_on:
turn_off:
comet424
(Comet424)
March 14, 2025, 4:11pm
17
ya had that but that gave me orginal error before the orginal post
Invalid config for 'homeassistant' at packages/house/dehumidifier.yaml, line 1: expected dict for dictionary value 'packages->house_dehumidifier', got None
house_dehumidifier:
switch:
switches:
dehumidifier_3:
turn_on:
turn_off:
dehumidifier_4:
turn_on:
turn_off:
Mikefila
(Mike Fila)
March 14, 2025, 4:14pm
18
Switch needs to be indented 2 spaces
house_dehumidifier:
switch:
comet424
(Comet424)
March 14, 2025, 4:26pm
19
house_dehumidifier:
switch:
switches:
dehumidifier_3:
turn_on:
turn_off:
dehumidifier_4:
turn_on:
turn_off:
Mikefila
(Mike Fila)
March 14, 2025, 5:00pm
20
You need to go over your spacing and formatting again. I entreated this in config.yaml
Created the folder structure
Used this yaml file, I switched the entity to one in my install
house_dehumidifier:
switch:
switches:
dehumidifier_3:
value_template: "{{ is_state('switch.kitchen_counter', 'on') }}"
turn_on:
entity_id: switch.kitchen_counter
turn_off:
dehumidifier_4:
turn_on:
turn_off:
and
