Need help with Keyboard Input Events Mulitpe Events for 1 Key Press
so i trying to add a numpad and i have worked out all the buttons i think gotta double check… but the = sign has 3 Event buttons to that input… how do you read 3 keys code 1 button?
/15/2024, 4:20:23 PMnode: debug 32
keyboard_remote_command_received : msg.payload : Object
{ event_type: "keyboard_remote_command_receiv…", entity_id: undefined, event: object, origin: "LOCAL", time_fired: "2024-07-15T20:20:24.058876+00:…" … }
7/15/2024, 4:20:23 PMnode: debug 32
object
event_type: "keyboard_remote_command_received"
event: object
origin: "LOCAL"
time_fired: "2024-07-15T20:20:24.074987+00:00"
context: object
object
event: object
key_code: 56
type: "key_down"
device_descriptor: "/dev/input/by-id/usb-SINO_WEALTH_2.4G吠漀甀挀栀 䬀攀礀戀漀愀爀搀-event-kbd"
device_name: "SINO WEALTH 2.4G吠漀甀挀栀 䬀攀礀戀漀愀爀搀"
origin: "LOCAL"
time_fired: "2024-07-15T20:20:24.091146+00:00"
context: object
object
event: object
origin: "LOCAL"
time_fired: "2024-07-15T20:20:24.091190+00:00"
context: object
object
event: object
origin: "LOCAL"
time_fired: "2024-07-15T20:20:24.091213+00:00"
context: object
object
event: object
key_code: 56
type: "key_up"
origin: "LOCAL"
time_fired: "2024-07-15T20:20:24.107322+00:00"
context: object
object
event: object
key_code: 77
type: "key_up"
origin: "LOCAL"
time_fired: "2024-07-15T20:20:24.107373+00:00"
context: object
object
event: object
key_code: 79
type: "key_up"
origin: "LOCAL"
time_fired: "2024-07-15T20:20:24.107394+00:00"
context: object
object
event: object
key_code: 69
type: "key_down"
origin: "LOCAL"
time_fired: "2024-07-15T20:20:24.123557+00:00"
context: object
object
event: object
key_code: 69
type: "key_up"
origin: "LOCAL"
time_fired: "2024-07-15T20:20:24.139684+00:00"
context: object
69 you can toss out that seems to be on all the buttons sometimes sends at begging and after the code button is sent
and here is my code checker
[{"id":"0ff812157740bed6","type":"server-events","z":"33e857f1856f9992","name":"","server":"915baa48.9b1898","version":3,"exposeAsEntityConfig":"","eventType":"keyboard_remote_command_received","eventData":"","waitForRunning":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"$outputData(\"eventData\").event_type","valueType":"jsonata"}],"x":170,"y":3460,"wires":[["6968bbdc12ed169a"]]},{"id":"6968bbdc12ed169a","type":"switch","z":"33e857f1856f9992","name":"which device","property":"payload.event.device_descriptor","propertyType":"msg","rules":[{"t":"eq","v":"/dev/input/by-id/usb-SINO_WEALTH_2.4G吠漀甀挀栀 䬀攀礀戀漀愀爀搀-event-kbd","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":450,"y":3460,"wires":[["72fc9fc0c405cbed","7b33153e496f57f0"]]},{"id":"94ba3a21c0d77f3b","type":"switch","z":"33e857f1856f9992","name":"which Button","property":"payload.event.key_code","propertyType":"msg","rules":[{"t":"eq","v":"79","vt":"num"},{"t":"eq","v":"80","vt":"num"},{"t":"eq","v":"78","vt":"num"},{"t":"eq","v":"74","vt":"num"}],"checkall":"true","repair":false,"outputs":4,"x":730,"y":3460,"wires":[[],[],[],[]]},{"id":"7b33153e496f57f0","type":"debug","z":"33e857f1856f9992","name":"debug 32","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":620,"y":3320,"wires":[]},{"id":"72fc9fc0c405cbed","type":"switch","z":"33e857f1856f9992","name":"key up","property":"payload.event.type","propertyType":"msg","rules":[{"t":"eq","v":"key_up","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":590,"y":3460,"wires":[["94ba3a21c0d77f3b"]]},{"id":"915baa48.9b1898","type":"server","name":"Home Assistant","version":5,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":"30","areaSelector":"friendlyName","deviceSelector":"friendlyName","entitySelector":"friendlyName","statusSeparator":"at: ","statusYear":"hidden","statusMonth":"short","statusDay":"numeric","statusHourCycle":"h23","statusTimeFormat":"h:m","enableGlobalContextStore":true}]
and whats a problem is 77 is also a number button… so if i have button doing something for 77 when i press = sign it will run that routine too
so it makes things hay wire… unless its something i cant fix?
