Dear All,
Need your help to set up integration with Alexa locally, without cloud integration of NabuCasa.
Appreciate pointers to get this done.
Thanks in advance.
Abhay
Not sure what your use cases are but if you are looking to play media on your alexa devices, control volume, next track…etc then you can use the Alexa Media Player integration via HACS.
If you dont have HACS alrady installed you should goggle how to install HACS in home assistant you will find various YouTube videos which will talk you through the process. Once installed click the HACS icon then integrations and search for alexa.
Thanks for the suggestion, will try it out.
