Hello, im new with Hassio, trying to following this guide Lovelace Slideshow Card [not allowd to link becasue im new user, weird rule] to get a slideshow on my dashboard. But doing something wrong but i dont know what.
- Create a folder in your
config
directory namedcustom_components
Check - Create a folder in your
custom_components
namedsensor
Check - Copy the
folder.py
into thesensor
folder Check - Add the folder sensor to your configuration.yaml file Check?
This is what my config file looks like, i think its okey,
Configure a default setup of Home Assistant (frontend, api, etc)
Uncomment this if you are using SSL/TLS, running in Docker container, etc.
http:
base_url: example.duckdns.org:8123
Text to speech
tts:
- platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
logger:
default: critical
logs:
# log level for HA core
homeassistant.core: fatal
frontend:
themes: !include_dir_merge_named themessensor:
- platform: folder
folder: /config/www/images
WWW
folder namedimages
Check - Add your images to this folder Check
- Restart Home Assistant Check
- Check the sensor.images entity to see if the
fileList
attribute lists your image files - Add a card to your ui-lovelace.yaml â does not work
its just says No card type configured
- type: âcustom:slideshow-cardâ
folder: sensor.images
Installation
- Copy
slideshow-card.js
to<config directory>/www/slideshow-card.js
Check - Add
slideshow-card
as a resource inui-lovelace.yaml
Screenshot by Lightshot
what am i doing wrong?
// Tobias
