Need help with MariaDB addon
I am trying to set up MariaDB on my RPi hass.io system. I have installed the MariaDB addon from the repo and entered the following in the config:
  "databases": [
    "homeassistant"
  "logins": [
      "username": "hass",
      "host": "core-mariadb",
      "password": "myownpassword"
  "rights": [
      "username": "hass",
      "database": "homeassistant",
      "grant": "ALL PRIVILEGES ON"
The addon is started and the end of the log file reads:
[INFO] Start MariaDB
171115 19:06:17 mysqld_safe Logging to '/data/databases/core-mariadb.err'.
171115 19:06:17 mysqld_safe Starting mysqld daemon with databases from /data/databases
[INFO] Init custom database
[INFO] Create database homeassistant
[INFO] Init/Update users
[INFO] Create user hass
[INFO] Init/Update rights
[INFO] Alter rights for hass@core-mariadb - homeassistant
I have also added the following to my configuration.yaml:
recorder:
  db_url: mysql://hass:myownpassword@core-mariadb/homeassistant
This is the error I get in the home-assistant.log:
2017-11-15 19:14:24 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (_mysql_exceptions.OperationalError) (1130, "Host 'homeassistant' is not allowed to connect to this MariaDB server") (retrying in 3 seconds)
2017-11-15 19:14:27 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (_mysql_exceptions.OperationalError) (1130, "Host 'homeassistant' is not allowed to connect to this MariaDB server") (retrying in 3 seconds)
I have tried to follow the instructions here, but it looks as if hass.io and the MariaDB addon are supposed to do most of the job for me. Am I missing some steps in the process?
I struggled too. Here is what I ended up using that works.
“databases”: [
“homeassistant”
“logins”: [
“username”: “hass”,
“host”: “homeassistant”,
“password”: “my-password”
“rights”: [
“username”: “hass”,
“database”: “homeassistant”,
“grant”: “ALL PRIVILEGES ON”
From my configuration.yaml file
db_url: mysql://hass:my-password@core-mariadb/homeassistant
Thanks, that seemed to work! No more errors. I am a bit curious though, where the database is stored. I guess the /config/home-assistant_v2.db i just the old one remaining?
Hi, I also have a bit of problem with MariaDB addon.
It does work, but I cannot open Logbook and History.
Anyone know what the problem might be?
This addon is working for me and can access via SQLAlchemy:
SOLVED:
I had the same problem and no matter what i tried I kept getting connection refused message in the logs.
To test what is wrong I attempted to connect from the outside haas from my laptop using MYSqlWorkbench app. I saw the same error as connection refused for “haas” user Then I changed the host name in both sections of the MariaDB host="%" , but still continued seeing the error.
Then I decided to create a NEW user “haas_admin” and all of a sudden I was able to connect from my laptop. I immediately went back to my configuration.yaml file and changed to the connection string to use this new uer. And everything started working like a charm.
I don’t know the reason for it, but maybe add-on is not properly making changes to a username that was previosly created with wrong configuration options. (though I am not sure about it)
Anyway, here is a working config (I added an additional user without removing a non-working haas user. ) I will try later to delete the original haas user from the config, but for now just posting what worked for me as is.
  "databases": [
    "homeassistant"
  "logins": [
      "username": "hass",
      "host": "homeassistant",
      "password": "mypassword"
      "username": "haas_admin",
      "host": "%",
      "password": "my-password"
  "rights": [
      "username": "hass",
      "host": "%",
And this is a connect string:
mdb_url: mysql://haas_admin:my-password@core-mariadb/homeassistant?charset=utf8
Hope creating a different user will resolve somebody’s problem.
Note: using “%” for host allow connections from inside home-assistant and from outside.
So, how do I find the database? How do i even verify that stuff is going into it? The addon says it is running and my old database is not growing.
I am looking for something that tells me it is work and the functional state.
In order to get it to work, I did have to add a second user and set the host to “%”
Hi, I have your same problem. You solved? Do you know how to find the homeassistant folder from a mysql manager?
For those who still struggle with the above instructions to get the MariaDB addon working in hass.io try using your hassio ip (or localhost) in the recorder db_url instead of the core-mariadb
ie.
db_url: mysql://haas_admin:[email protected]/homeassistant?charset=utf8
instead of:
Thank you very much. This helped solve my problem.
Ok,
But there is a way to migrate from sqlite3 to mariadb for managing the old history?
I suspect that the following,
‘mysql://homeassistant:password@’
Should be,
‘mysql://MYADMINACCOUNT:MYPASSWORD@’
Also, would restoring from a previous snapshot cause any issues? What was in the previous database be restored to the MariaDB? If not, is there a migration path?
