Need help with modbus setup
Hello everyone! I have a home control system with Modbus, which works well. And recently I installed two frequency inverters on the ventilation unit. I am trying to connect these inverters to my Modbus network, but I fail. The inverters have an unfamiliar address system and functions. I can not make them control by Modbus or provide any data. I have a full description of the Modbus protocol for these inverters. But I do not have enough knowledge to make it work. I am looking for any help to write the correct code for Modbus. Free or for money. Please. help me!
Modbus.doc
type or paste code heremodbus:
  - name: modbus_0
    type: serial
    method: rtu
    port: /dev/ttyUSB1
    baudrate: 9600
    stopbits: 2
    bytesize: 8
    parity: N
    timeout: 2
    switches:
      - name: "air_cool_pump"
        slave: 98
        address: 5
        unique_id: air_cool_pump
        write_type: coil
      - name: "sauna_hiter"
        slave: 74
        address: 2
        unique_id: sauna_hiter
        write_type: coil
 #     - name: "hit_p_circ_pump"
  #      slave: 74
   #     address: 4
    #    unique_id: hit_p_circ_pump
     #   write_type: coil
      - name: "sun_mode_boost"
        slave: 74
        address: 1
        unique_id: sun_mode_boost
        write_type: coil
      - name: "main_water_valve_open"
        slave: 98
        address: 3
        unique_id: main_water_valve_open
        write_type: coil
      - name: "main_water_valve_close"
        slave: 98
        address: 4
        unique_id: main_water_valve_close
        write_type: coil
      - name: "air cooli_hit_valve_cool"
        slave: 98
        address: 1
        unique_id: air cooli_hit_valve_cool
        write_type: coil
      - name: "air cooli_hit_valve_hitt"
        slave: 98
        address: 2
        unique_id: air cooli_hit_valve_hitt
        write_type: coil
      - name: "sauna_contactor"
        slave: 98
        address: 0
        unique_id: sauna_contactor
        write_type: coil
        scan_interval: 5
      - name: "garage_gate"
        slave: 74
        address: 0
        unique_id: garage_gate
        write_type: coil
    sensors:
      - name: vent_temp_1
        unique_id: vent_temp_1
       # unit_of_measurement: °C
        slave: 107
        address: 246
       # scale: 00.13
        offset: 0
        precision: 1
        scan_interval: 30
      - name: vent_temp_2
        unique_id: vent_temp_2
        slave: 107
        address: 247
      #  scale: 00.13
        offset: 0
        precision: 1
        scan_interval: 30
    binary_sensors:
      - name: DI_1
        unique_id: DI_1
        slave: 74
        address: 0
        input_type: discrete_input
      - name: DI_2
        unique_id: DI_2
        slave: 74
        address: 1
      - name: DI_3
        unique_id: DI_3
        slave: 74
        address: 2
      - name: DI_4
        unique_id: DI_4
        slave: 74
        address: 3
      - name: DI_5
        unique_id: DI_5
        slave: 74
        address: 4
      - name: DI_6
        unique_id: DI_6
        slave: 74
        address: 5
      - name: DI_7
        unique_id: DI_7
        slave: 74
        address: 6
      - name: DI_8
        unique_id: DI_8
        slave: 98
        address: 0
      - name: DI_9
        unique_id: DI_9
        slave: 98
        address: 1
      - name: DI_10
        unique_id: DI_10
        slave: 98
        address: 2
      - name: DI_11
        unique_id: DI_13
        slave: 98
        address: 3
      - name: pump_septik
        slave: 98
        address: 4
        unique_id: pump_septik
      - name: garage_door_contact
        slave: 98
        address: 5
        unique_id: garage_door_contact
      - name: DI_14
        unique_id: DI_14
        slave: 98
        address: 6
#        scan_interval: 1
