If you don’t see any debug logging, there must be something wrong with your HA installation. Just turned on debug, 5 minutes log : (too big to post, will have to cut some)
2020-03-20 20:06:57 DEBUG (MainThread) [homeassistant.components.mqtt] Subscribing to homeassistant/#
2020-03-20 20:07:00 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on homeassistant/switch/0x000d6ffffefd3b79/switch/config (retained): b'{"payload_off":"OFF","payload_on":"ON","value_template":"{{ value_json.state }}","command_topic":"zigbee2mqtt/ikeaoutlet1/set","state_topic":"zigbee2mqtt/ikeaoutlet1","json_attributes_topic":"zigbee2mqtt/ikeaoutlet1","name":"ikeaoutlet1_switch","unique_id":"0x000d6ffffefd3b79_switch_zigbee2mqtt","device":{"identifiers":["zigbee2mqtt_0x000d6ffffefd3b79"],"name":"ikeaoutlet1","sw_version":"Zigbee2mqtt 1.12.0","model":"TRADFRI control outlet (E1603/E1702)","manufacturer":"IKEA"},"availability_topic":"zigbee2mqtt/bridge/state"}'
2020-03-20 20:07:00 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on homeassistant/switch/0x000d6ffffea93230/switch/config (retained): b'{"payload_off":"OFF","payload_on":"ON","value_template":"{{ value_json.state }}","command_topic":"zigbee2mqtt/ikeaoutlet3/set","state_topic":"zigbee2mqtt/ikeaoutlet3","json_attributes_topic":"zigbee2mqtt/ikeaoutlet3","name":"ikeaoutlet3_switch","unique_id":"0x000d6ffffea93230_switch_zigbee2mqtt","device":{"identifiers":["zigbee2mqtt_0x000d6ffffea93230"],"name":"ikeaoutlet3","sw_version":"Zigbee2mqtt 1.12.0","model":"TRADFRI control outlet (E1603/E1702)","manufacturer":"IKEA"},"availability_topic":"zigbee2mqtt/bridge/state"}'
2020-03-20 20:07:00 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on homeassistant/switch/0x000d6ffffea7d4c7/switch/config (retained): b'{"payload_off":"OFF","payload_on":"ON","value_template":"{{ value_json.state }}","command_topic":"zigbee2mqtt/ikeaoutlet2/set","state_topic":"zigbee2mqtt/ikeaoutlet2","json_attributes_topic":"zigbee2mqtt/ikeaoutlet2","name":"ikeaoutlet2_switch","unique_id":"0x000d6ffffea7d4c7_switch_zigbee2mqtt","device":{"identifiers":["zigbee2mqtt_0x000d6ffffea7d4c7"],"name":"ikeaoutlet2","sw_version":"Zigbee2mqtt 1.12.0","model":"TRADFRI control outlet (E1603/E1702)","manufacturer":"IKEA"},"availability_topic":"zigbee2mqtt/bridge/state"}'
2020-03-20 20:07:00 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on homeassistant/switch/0x000d6ffffefd3bf8/switch/config (retained): b'{"payload_off":"OFF","payload_on":"ON","value_template":"{{ value_json.state }}","command_topic":"zigbee2mqtt/ikeaoutlet4/set","state_topic":"zigbee2mqtt/ikeaoutlet4","json_attributes_topic":"zigbee2mqtt/ikeaoutlet4","name":"ikeaoutlet4_switch","unique_id":"0x000d6ffffefd3bf8_switch_zigbee2mqtt","device":{"identifiers":["zigbee2mqtt_0x000d6ffffefd3bf8"],"name":"ikeaoutlet4","sw_version":"Zigbee2mqtt 1.12.0","model":"TRADFRI control outlet (E1603/E1702)","manufacturer":"IKEA"},"availability_topic":"zigbee2mqtt/bridge/state"}'
2020-03-20 20:07:00 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on homeassistant/switch/0x086bd7fffe5b3df5/switch/config (retained): b'{"payload_off":"OFF","payload_on":"ON","value_template":"{{ value_json.state }}","command_topic":"zigbee2mqtt/ikeaoutlet5/set","state_topic":"zigbee2mqtt/ikeaoutlet5","json_attributes_topic":"zigbee2mqtt/ikeaoutlet5","name":"ikeaoutlet5_switch","unique_id":"0x086bd7fffe5b3df5_switch_zigbee2mqtt","device":{"identifiers":["zigbee2mqtt_0x086bd7fffe5b3df5"],"name":"ikeaoutlet5","sw_version":"Zigbee2mqtt 1.12.0","model":"TRADFRI control outlet (E1603/E1702)","manufacturer":"IKEA"},"availability_topic":"zigbee2mqtt/bridge/state"}'
2020-03-20 20:07:00 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on homeassistant/switch/C6D98E_RL_1/config (retained): b'{"name":"SonoffBasic3","cmd_t":"~cmnd/POWER","stat_t":"~tele/STATE","val_tpl":"{{value_json.POWER}}","pl_off":"OFF","pl_on":"ON","avty_t":"~tele/LWT","pl_avail":"Online","pl_not_avail":"Offline","uniq_id":"C6D98E_RL_1","device":{"identifiers":["C6D98E"],"connections":[["mac","60:01:94:C6:D9:8E"]]},"~":"SonoffBasic3/"}'
2020-03-20 20:07:00 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on homeassistant/switch/9F20A8_RL_1/config (retained): b'{"name":"Qia","cmd_t":"~cmnd/POWER","stat_t":"~tele/STATE","val_tpl":"{{value_json.POWER}}","pl_off":"OFF","pl_on":"ON","avty_t":"~tele/LWT","pl_avail":"Online","pl_not_avail":"Offline","uniq_id":"9F20A8_RL_1","device":{"identifiers":["9F20A8"],"connections":[["mac","EC:FA:BC:9F:20:A8"]]},"~":"Qia/"}'
2020-03-20 20:07:00 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on homeassistant/switch/CE0D83_RL_1/config (retained): b'{"name":"switchvooraangrotelichten","cmd_t":"~cmnd/POWER1","stat_t":"~tele/STATE","val_tpl":"{{value_json.POWER1}}","pl_off":"OFF","pl_on":"ON","avty_t":"~tele/LWT","pl_avail":"Online","pl_not_avail":"Offline","uniq_id":"CE0D83_RL_1","device":{"identifiers":["CE0D83"]},"~":"sonoff4ch/"}'
2020-03-20 20:07:00 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on homeassistant/switch/CE0D83_RL_2/config (retained): b'{"name":"switchvooraandeur","cmd_t":"~cmnd/POWER2","stat_t":"~tele/STATE","val_tpl":"{{value_json.POWER2}}","pl_off":"OFF","pl_on":"ON","avty_t":"~tele/LWT","pl_avail":"Online","pl_not_avail":"Offline","uniq_id":"CE0D83_RL_2","device":{"identifiers":["CE0D83"]},"~":"sonoff4ch/"}'
2020-03-20 20:07:00 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on homeassistant/switch/CE0D83_RL_3/config (retained): b'{"name":"switchvooraankleinelichten","cmd_t":"~cmnd/POWER3","stat_t":"~tele/STATE","val_tpl":"{{value_json.POWER3}}","pl_off":"OFF","pl_on":"ON","avty_t":"~tele/LWT","pl_avail":"Online","pl_not_avail":"Offline","uniq_id":"CE0D83_RL_3","device":{"identifiers":["CE0D83"]},"~":"sonoff4ch/"}'
2020-03-20 20:07:00 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on homeassistant/switch/CE0D83_RL_4/config (retained): b'{"name":"Sonoff4ch4","cmd_t":"~cmnd/POWER4","stat_t":"~tele/STATE","val_tpl":"{{value_json.POWER4}}","pl_off":"OFF","pl_on":"ON","avty_t":"~tele/LWT","pl_avail":"Online","pl_not_avail":"Offline","uniq_id":"CE0D83_RL_4","device":{"identifiers":["CE0D83"]},"~":"sonoff4ch/"}'
2020-03-20 20:07:00 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on homeassistant/switch/193EF5_RL_1/config (retained): b'{"name":"powr2","cmd_t":"~cmnd/POWER","stat_t":"~tele/STATE","val_tpl":"{{value_json.POWER}}","pl_off":"OFF","pl_on":"ON","avty_t":"~tele/LWT","pl_avail":"Online","pl_not_avail":"Offline","uniq_id":"193EF5_RL_1","device":{"identifiers":["193EF5"]},"~":"powr2/"}'
2020-03-20 20:07:00 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on homeassistant/switch/DB45F2_RL_1/config (retained): b'{"name":"Sonoff1","cmd_t":"~cmnd/POWER1","stat_t":"~tele/STATE","val_tpl":"{{value_json.POWER1}}","pl_off":"OFF","pl_on":"ON","avty_t":"~tele/LWT","pl_avail":"Online","pl_not_avail":"Offline","uniq_id":"DB45F2_RL_1","device":{"identifiers":["DB45F2"]},"~":"sonoff4chpro/"}'
2020-03-20 20:07:00 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on homeassistant/switch/DB45F2_RL_2/config (retained): b'{"name":"Sonoff2","cmd_t":"~cmnd/POWER2","stat_t":"~tele/STATE","val_tpl":"{{value_json.POWER2}}","pl_off":"OFF","pl_on":"ON","avty_t":"~tele/LWT","pl_avail":"Online","pl_not_avail":"Offline","uniq_id":"DB45F2_RL_2","device":{"identifiers":["DB45F2"]},"~":"sonoff4chpro/"}'
2020-03-20 20:07:00 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on homeassistant/switch/DB45F2_RL_3/config (retained): b'{"name":"Sonoff3","cmd_t":"~cmnd/POWER3","stat_t":"~tele/STATE","val_tpl":"{{value_json.POWER3}}","pl_off":"OFF","pl_on":"ON","avty_t":"~tele/LWT","pl_avail":"Online","pl_not_avail":"Offline","uniq_id":"DB45F2_RL_3","device":{"identifiers":["DB45F2"]},"~":"sonoff4chpro/"}'
2020-03-20 20:07:00 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on homeassistant/switch/DB45F2_RL_4/config (retained): b'{"name":"Sonoff4","cmd_t":"~cmnd/POWER4","stat_t":"~tele/STATE","val_tpl":"{{value_json.POWER4}}","pl_off":"OFF","pl_on":"ON","avty_t":"~tele/LWT","pl_avail":"Online","pl_not_avail":"Offline","uniq_id":"DB45F2_RL_4","device":{"identifiers":["DB45F2"]},"~":"sonoff4chpro/"}'
2020-03-20 20:07:00 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on homeassistant/sensor/0x000d6ffffefd3b79/linkquality/config (retained): b'{"icon":"mdi:signal","unit_of_measurement":"lqi","value_template":"{{ value_json.linkquality }}","state_topic":"zigbee2mqtt/ikeaoutlet1","json_attributes_topic":"zigbee2mqtt/ikeaoutlet1","name":"ikeaoutlet1_linkquality","unique_id":"0x000d6ffffefd3b79_linkquality_zigbee2mqtt","device":{"identifiers":["zigbee2mqtt_0x000d6ffffefd3b79"],"name":"ikeaoutlet1","sw_version":"Zigbee2mqtt 1.12.0","model":"TRADFRI control outlet (E1603/E1702)","manufacturer":"IKEA"},"availability_topic":"zigbee2mqtt/bridge/state"}'
2020-03-20 20:07:00 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on homeassistant/sensor/0x000d6ffffea93230/linkquality/config (retained): b'{"icon":"mdi:signal","unit_of_measurement":"lqi","value_template":"{{ value_json.linkquality }}","state_topic":"zigbee2mqtt/ikeaoutlet3","json_attributes_topic":"zigbee2mqtt/ikeaoutlet3","name":"ikeaoutlet3_linkquality","unique_id":"0x000d6ffffea93230_linkquality_zigbee2mqtt","device":{"identifiers":["zigbee2mqtt_0x000d6ffffea93230"],"name":"ikeaoutlet3","sw_version":"Zigbee2mqtt 1.12.0","model":"TRADFRI control outlet (E1603/E1702)","manufacturer":"IKEA"},"availability_topic":"zigbee2mqtt/bridge/state"}'
2020-03-20 20:07:00 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on homeassistant/sensor/0x000d6ffffea7d4c7/linkquality/config (retained): b'{"icon":"mdi:signal","unit_of_measurement":"lqi","value_template":"{{ value_json.linkquality }}","state_topic":"zigbee2mqtt/ikeaoutlet2","json_attributes_topic":"zigbee2mqtt/ikeaoutlet2","name":"ikeaoutlet2_linkquality","unique_id":"0x000d6ffffea7d4c7_linkquality_zigbee2mqtt","device":{"identifiers":["zigbee2mqtt_0x000d6ffffea7d4c7"],"name":"ikeaoutlet2","sw_version":"Zigbee2mqtt 1.12.0","model":"TRADFRI control outlet (E1603/E1702)","manufacturer":"IKEA"},"availability_topic":"zigbee2mqtt/bridge/state"}'
2020-03-20 20:07:00 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on homeassistant/sensor/0x000d6ffffefd3bf8/linkquality/config (retained): b'{"icon":"mdi:signal","unit_of_measurement":"lqi","value_template":"{{ value_json.linkquality }}","state_topic":"zigbee2mqtt/ikeaoutlet4","json_attributes_topic":"zigbee2mqtt/ikeaoutlet4","name":"ikeaoutlet4_linkquality","unique_id":"0x000d6ffffefd3bf8_linkquality_zigbee2mqtt","device":{"identifiers":["zigbee2mqtt_0x000d6ffffefd3bf8"],"name":"ikeaoutlet4","sw_version":"Zigbee2mqtt 1.12.0","model":"TRADFRI control outlet (E1603/E1702)","manufacturer":"IKEA"},"availability_topic":"zigbee2mqtt/bridge/state"}'
2020-03-20 20:07:00 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on homeassistant/sensor/0x000d6ffffeac1f8a/click/config (retained): b'{"icon":"mdi:toggle-switch","value_template":"{{ value_json.click }}","state_topic":"zigbee2mqtt/ikea_button1","json_attributes_topic":"zigbee2mqtt/ikea_button1","name":"ikea_button1_click","unique_id":"0x000d6ffffeac1f8a_click_zigbee2mqtt","device":{"identifiers":["zigbee2mqtt_0x000d6ffffeac1f8a"],"name":"ikea_button1","sw_version":"Zigbee2mqtt 1.12.0","model":"TRADFRI ON/OFF switch (E1743)","manufacturer":"IKEA"},"availability_topic":"zigbee2mqtt/bridge/state"}'
2020-03-20 20:07:00 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on homeassistant/sensor/0x000d6ffffeac1f8a/battery/config (retained): b'{"unit_of_measurement":"%","device_class":"battery","value_template":"{{ value_json.battery }}","state_topic":"zigbee2mqtt/ikea_button1","json_attributes_topic":"zigbee2mqtt/ikea_button1","name":"ikea_button1_battery","unique_id":"0x000d6ffffeac1f8a_battery_zigbee2mqtt","device":{"identifiers":["zigbee2mqtt_0x000d6ffffeac1f8a"],"name":"ikea_button1","sw_version":"Zigbee2mqtt 1.12.0","model":"TRADFRI ON/OFF switch (E1743)","manufacturer":"IKEA"},"availability_topic":"zigbee2mqtt/bridge/state"}'
2020-03-20 20:07:00 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on homeassistant/sensor/0x000d6ffffeac1f8a/linkquality/config (retained): b'{"icon":"mdi:signal","unit_of_measurement":"lqi","value_template":"{{ value_json.linkquality }}","state_topic":"zigbee2mqtt/ikea_button1","json_attributes_topic":"zigbee2mqtt/ikea_button1","name":"ikea_button1_linkquality","unique_id":"0x000d6ffffeac1f8a_linkquality_zigbee2mqtt","device":{"identifiers":["zigbee2mqtt_0x000d6ffffeac1f8a"],"name":"ikea_button1","sw_version":"Zigbee2mqtt 1.12.0","model":"TRADFRI ON/OFF switch (E1743)","manufacturer":"IKEA"},"availability_topic":"zigbee2mqtt/bridge/state"}'
2020-03-20 20:07:00 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on homeassistant/sensor/0x00124b0018e25f2a/linkquality/config (retained): b'{"icon":"mdi:signal","unit_of_measurement":"lqi","value_template":"{{ value_json.linkquality }}","state_topic":"zigbee2mqtt/CC2531","json_attributes_topic":"zigbee2mqtt/CC2531","name":"CC2531_linkquality","unique_id":"0x00124b0018e25f2a_linkquality_zigbee2mqtt","device":{"identifiers":["zigbee2mqtt_0x00124b0018e25f2a"],"name":"CC2531","sw_version":"Zigbee2mqtt 1.12.0","model":"[CC2530 router](http://ptvo.info/cc2530-based-zigbee-coordinator-and-router-112/) (CC2530.ROUTER)","manufacturer":"Custom devices (DiY)"},"availability_topic":"zigbee2mqtt/bridge/state"}'
2020-03-20 20:07:00 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on homeassistant/sensor/0x00158d000445703e/temperature/config (retained): b'{"unit_of_measurement":"\xc2\xb0C","device_class":"temperature","value_template":"{{ value_json.temperature }}","state_topic":"zigbee2mqtt/temp_slaapkamer","json_attributes_topic":"zigbee2mqtt/temp_slaapkamer","name":"temp_slaapkamer_temperature","unique_id":"0x00158d000445703e_temperature_zigbee2mqtt","device":{"identifiers":["zigbee2mqtt_0x00158d000445703e"],"name":"temp_slaapkamer","sw_version":"Zigbee2mqtt 1.12.0","model":"MiJia temperature & humidity sensor (WSDCGQ01LM)","manufacturer":"Xiaomi"},"availability_topic":"zigbee2mqtt/bridge/state"}'
2020-03-20 20:07:00 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on homeassistant/sensor/0x00158d000445703e/humidity/config (retained): b'{"unit_of_measurement":"%","device_class":"humidity","value_template":"{{ value_json.humidity }}","state_topic":"zigbee2mqtt/temp_slaapkamer","json_attributes_topic":"zigbee2mqtt/temp_slaapkamer","name":"temp_slaapkamer_humidity","unique_id":"0x00158d000445703e_humidity_zigbee2mqtt","device":{"identifiers":["zigbee2mqtt_0x00158d000445703e"],"name":"temp_slaapkamer","sw_version":"Zigbee2mqtt 1.12.0","model":"MiJia temperature & humidity sensor (WSDCGQ01LM)","manufacturer":"Xiaomi"},"availability_topic":"zigbee2mqtt/bridge/state"}'
2020-03-20 20:07:00 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on homeassistant/sensor/0x00158d000445703e/battery/config (retained): b'{"unit_of_measurement":"%","device_class":"battery","value_template":"{{ value_json.battery }}","state_topic":"zigbee2mqtt/temp_slaapkamer","json_attributes_topic":"zigbee2mqtt/temp_slaapkamer","name":"temp_slaapkamer_battery","unique_id":"0x00158d000445703e_battery_zigbee2mqtt","device":{"identifiers":["zigbee2mqtt_0x00158d000445703e"],"name":"temp_slaapkamer","sw_version":"Zigbee2mqtt 1.12.0","model":"MiJia temperature & humidity sensor (WSDCGQ01LM)","manufacturer":"Xiaomi"},"availability_topic":"zigbee2mqtt/bridge/state"}'
2020-03-20 20:07:00 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on homeassistant/sensor/0x00158d000445703e/linkquality/config (retained): b'{"icon":"mdi:signal","unit_of_measurement":"lqi","value_template":"{{ value_json.linkquality }}","state_topic":"zigbee2mqtt/temp_slaapkamer","json_attributes_topic":"zigbee2mqtt/temp_slaapkamer","name":"temp_slaapkamer_linkquality","unique_id":"0x00158d000445703e_linkquality_zigbee2mqtt","device":{"identifiers":["zigbee2mqtt_0x00158d000445703e"],"name":"temp_slaapkamer","sw_version":"Zigbee2mqtt 1.12.0","model":"MiJia temperature & humidity sensor (WSDCGQ01LM)","manufacturer":"Xiaomi"},"availability_topic":"zigbee2mqtt/bridge/state"}'
2020-03-20 20:07:00 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on homeassistant/sensor/0x14b457fffe49ecf4/battery/config (retained): b'{"unit_of_measurement":"%","device_class":"battery","value_template":"{{ value_json.battery }}","state_topic":"zigbee2mqtt/ikeapir","json_attributes_topic":"zigbee2mqtt/ikeapir","name":"ikeapir_battery","unique_id":"0x14b457fffe49ecf4_battery_zigbee2mqtt","device":{"identifiers":["zigbee2mqtt_0x14b457fffe49ecf4"],"name":"ikeapir","sw_version":"Zigbee2mqtt 1.12.0","model":"TRADFRI motion sensor (E1525/E1745)","manufacturer":"IKEA"},"availability_topic":"zigbee2mqtt/bridge/state"}'
2020-03-20 20:07:00 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on homeassistant/sensor/0x14b457fffe49ecf4/linkquality/config (retained): b'{"icon":"mdi:signal","unit_of_measurement":"lqi","value_template":"{{ value_json.linkquality }}","state_topic":"zigbee2mqtt/ikeapir","json_attributes_topic":"zigbee2mqtt/ikeapir","name":"ikeapir_linkquality","unique_id":"0x14b457fffe49ecf4_linkquality_zigbee2mqtt","device":{"identifiers":["zigbee2mqtt_0x14b457fffe49ecf4"],"name":"ikeapir","sw_version":"Zigbee2mqtt 1.12.0","model":"TRADFRI motion sensor (E1525/E1745)","manufacturer":"IKEA"},"availability_topic":"zigbee2mqtt/bridge/state"}'
2020-03-20 20:07:00 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on homeassistant/sensor/0x00158d00034ce4e1/illuminance/config (retained): b'{"unit_of_measurement":"-","device_class":"illuminance","value_template":"{{ value_json.illuminance }}","state_topic":"zigbee2mqtt/aquara1","json_attributes_topic":"zigbee2mqtt/aquara1","name":"aquara1_illuminance","unique_id":"0x00158d00034ce4e1_illuminance_zigbee2mqtt","device":{"identifiers":["zigbee2mqtt_0x00158d00034ce4e1"],"name":"aquara1","sw_version":"Zigbee2mqtt 1.12.0","model":"Aqara human body movement and illuminance sensor (RTCGQ11LM)","manufacturer":"Xiaomi"},"availability_topic":"zigbee2mqtt/bridge/state"}'
2020-03-20 20:07:00 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on homeassistant/sensor/0x00158d00034ce4e1/battery/config (retained): b'{"unit_of_measurement":"%","device_class":"battery","value_template":"{{ value_json.battery }}","state_topic":"zigbee2mqtt/aquara1","json_attributes_topic":"zigbee2mqtt/aquara1","name":"aquara1_battery","unique_id":"0x00158d00034ce4e1_battery_zigbee2mqtt","device":{"identifiers":["zigbee2mqtt_0x00158d00034ce4e1"],"name":"aquara1","sw_version":"Zigbee2mqtt 1.12.0","model":"Aqara human body movement and illuminance sensor (RTCGQ11LM)","manufacturer":"Xiaomi"},"availability_topic":"zigbee2mqtt/bridge/state"}'
2020-03-20 20:07:00 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on homeassistant/sensor/0x00158d00034ce4e1/linkquality/config (retained): b'{"icon":"mdi:signal","unit_of_measurement":"lqi","value_template":"{{ value_json.linkquality }}","state_topic":"zigbee2mqtt/aquara1","json_attributes_topic":"zigbee2mqtt/aquara1","name":"aquara1_linkquality","unique_id":"0x00158d00034ce4e1_linkquality_zigbee2mqtt","device":{"identifiers":["zigbee2mqtt_0x00158d00034ce4e1"],"name":"aquara1","sw_version":"Zigbee2mqtt 1.12.0","model":"Aqara human body movement and illuminance sensor (RTCGQ11LM)","manufacturer":"Xiaomi"},"availability_topic":"zigbee2mqtt/bridge/state"}'
2020-03-20 20:07:00 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on homeassistant/sensor/0x086bd7fffe5b3df5/linkquality/config (retained): b'{"icon":"mdi:signal","unit_of_measurement":"lqi","value_template":"{{ value_json.linkquality }}","state_topic":"zigbee2mqtt/ikeaoutlet5","json_attributes_topic":"zigbee2mqtt/ikeaoutlet5","name":"ikeaoutlet5_linkquality","unique_id":"0x086bd7fffe5b3df5_linkquality_zigbee2mqtt","device":{"identifiers":["zigbee2mqtt_0x086bd7fffe5b3df5"],"name":"ikeaoutlet5","sw_version":"Zigbee2mqtt 1.12.0","model":"TRADFRI control outlet (E1603/E1702)","manufacturer":"IKEA"},"availability_topic":"zigbee2mqtt/bridge/state"}'
2020-03-20 20:07:00 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on homeassistant/sensor/0x000d6ffffe4a8700/battery/config (retained): b'{"unit_of_measurement":"%","device_class":"battery","value_template":"{{ value_json.battery }}","state_topic":"zigbee2mqtt/ikeapirboven","json_attributes_topic":"zigbee2mqtt/ikeapirboven","name":"ikeapirboven_battery","unique_id":"0x000d6ffffe4a8700_battery_zigbee2mqtt","device":{"identifiers":["zigbee2mqtt_0x000d6ffffe4a8700"],"name":"ikeapirboven","sw_version":"Zigbee2mqtt 1.12.0","model":"TRADFRI motion sensor (E1525/E1745)","manufacturer":"IKEA"},"availability_topic":"zigbee2mqtt/bridge/state"}'
2020-03-20 20:07:01 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on homeassistant/sensor/0x000d6ffffe4a8700/linkquality/config (retained): b'{"icon":"mdi:signal","unit_of_measurement":"lqi","value_template":"{{ value_json.linkquality }}","state_topic":"zigbee2mqtt/ikeapirboven","json_attributes_topic":"zigbee2mqtt/ikeapirboven","name":"ikeapirboven_linkquality","unique_id":"0x000d6ffffe4a8700_linkquality_zigbee2mqtt","device":{"identifiers":["zigbee2mqtt_0x000d6ffffe4a8700"],"name":"ikeapirboven","sw_version":"Zigbee2mqtt 1.12.0","model":"TRADFRI motion sensor (E1525/E1745)","manufacturer":"IKEA"},"availability_topic":"zigbee2mqtt/bridge/state"}'
2020-03-20 20:07:01 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on homeassistant/sensor/0xccccccfffe2fb287/battery/config (retained): b'{"unit_of_measurement":"%","device_class":"battery","value_template":"{{ value_json.battery }}","state_topic":"zigbee2mqtt/ikeapir2","json_attributes_topic":"zigbee2mqtt/ikeapir2","name":"ikeapir2_battery","unique_id":"0xccccccfffe2fb287_battery_zigbee2mqtt","device":{"identifiers":["zigbee2mqtt_0xccccccfffe2fb287"],"name":"ikeapir2","sw_version":"Zigbee2mqtt 1.12.0","model":"TRADFRI motion sensor (E1525/E1745)","manufacturer":"IKEA"},"availability_topic":"zigbee2mqtt/bridge/state"}'
2020-03-20 20:07:01 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on homeassistant/sensor/0xccccccfffe2fb287/linkquality/config (retained): b'{"icon":"mdi:signal","unit_of_measurement":"lqi","value_template":"{{ value_json.linkquality }}","state_topic":"zigbee2mqtt/ikeapir2","json_attributes_topic":"zigbee2mqtt/ikeapir2","name":"ikeapir2_linkquality","unique_id":"0xccccccfffe2fb287_linkquality_zigbee2mqtt","device":{"identifiers":["zigbee2mqtt_0xccccccfffe2fb287"],"name":"ikeapir2","sw_version":"Zigbee2mqtt 1.12.0","model":"TRADFRI motion sensor (E1525/E1745)","manufacturer":"IKEA"},"availability_topic":"zigbee2mqtt/bridge/state"}'
2020-03-20 20:07:01 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on homeassistant/sensor/0x00124b0008b9d933/linkquality/config (retained): b'{"icon":"mdi:signal","unit_of_measurement":"lqi","value_template":"{{ value_json.linkquality }}","state_topic":"zigbee2mqtt/CC2531router","json_attributes_topic":"zigbee2mqtt/CC2531router","name":"CC2531router_linkquality","unique_id":"0x00124b0008b9d933_linkquality_zigbee2mqtt","device":{"identifiers":["zigbee2mqtt_0x00124b0008b9d933"],"name":"CC2531router","sw_version":"Zigbee2mqtt 1.12.0","model":"[CC2530 router](http://ptvo.info/cc2530-based-zigbee-coordinator-and-router-112/) (CC2530.ROUTER)","manufacturer":"Custom devices (DiY)"},"availability_topic":"zigbee2mqtt/bridge/state"}'
2020-03-20 20:07:01 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on homeassistant/sensor/0x00124b001949ee9c/linkquality/config (retained): b'{"icon":"mdi:signal","unit_of_measurement":"lqi","value_template":"{{ value_json.linkquality }}","state_topic":"zigbee2mqtt/CC2531_ant","json_attributes_topic":"zigbee2mqtt/CC2531_ant","name":"CC2531_ant_linkquality","unique_id":"0x00124b001949ee9c_linkquality_zigbee2mqtt","device":{"identifiers":["zigbee2mqtt_0x00124b001949ee9c"],"name":"CC2531_ant","sw_version":"Zigbee2mqtt 1.12.0","model":"[CC2530 router](http://ptvo.info/cc2530-based-zigbee-coordinator-and-router-112/) (CC2530.ROUTER)","manufacturer":"Custom devices (DiY)"},"availability_topic":"zigbee2mqtt/bridge/state"}'
2020-03-20 20:07:01 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on homeassistant/sensor/0x00158d0003cc6b6d/temperature/config (retained): b'{"unit_of_measurement":"\xc2\xb0C","device_class":"temperature","value_template":"{{ value_json.temperature }}","state_topic":"zigbee2mqtt/temp_keuken","json_attributes_topic":"zigbee2mqtt/temp_keuken","name":"temp_keuken_temperature","unique_id":"0x00158d0003cc6b6d_temperature_zigbee2mqtt","device":{"identifiers":["zigbee2mqtt_0x00158d0003cc6b6d"],"name":"temp_keuken","sw_version":"Zigbee2mqtt 1.12.0","model":"MiJia temperature & humidity sensor (WSDCGQ01LM)","manufacturer":"Xiaomi"},"availability_topic":"zigbee2mqtt/bridge/state"}'
2020-03-20 20:07:01 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on homeassistant/sensor/0x00158d0003cc6b6d/humidity/config (retained): b'{"unit_of_measurement":"%","device_class":"humidity","value_template":"{{ value_json.humidity }}","state_topic":"zigbee2mqtt/temp_keuken","json_attributes_topic":"zigbee2mqtt/temp_keuken","name":"temp_keuken_humidity","unique_id":"0x00158d0003cc6b6d_humidity_zigbee2mqtt","device":{"identifiers":["zigbee2mqtt_0x00158d0003cc6b6d"],"name":"temp_keuken","sw_version":"Zigbee2mqtt 1.12.0","model":"MiJia temperature & humidity sensor (WSDCGQ01LM)","manufacturer":"Xiaomi"},"availability_topic":"zigbee2mqtt/bridge/state"}'
2020-03-20 20:07:01 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on homeassistant/sensor/0x00158d0003cc6b6d/battery/config (retained): b'{"unit_of_measurement":"%","device_class":"battery","value_template":"{{ value_json.battery }}","state_topic":"zigbee2mqtt/temp_keuken","json_attributes_topic":"zigbee2mqtt/temp_keuken","name":"temp_keuken_battery","unique_id":"0x00158d0003cc6b6d_battery_zigbee2mqtt","device":{"identifiers":["zigbee2mqtt_0x00158d0003cc6b6d"],"name":"temp_keuken","sw_version":"Zigbee2mqtt 1.12.0","model":"MiJia temperature & humidity sensor (WSDCGQ01LM)","manufacturer":"Xiaomi"},"availability_topic":"zigbee2mqtt/bridge/state"}'
2020-03-20 20:07:01 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on homeassistant/sensor/0x00158d0003cc6b6d/linkquality/config (retained): b'{"icon":"mdi:signal","unit_of_measurement":"lqi","value_template":"{{ value_json.linkquality }}","state_topic":"zigbee2mqtt/temp_keuken","json_attributes_topic":"zigbee2mqtt/temp_keuken","name":"temp_keuken_linkquality","unique_id":"0x00158d0003cc6b6d_linkquality_zigbee2mqtt","device":{"identifiers":["zigbee2mqtt_0x00158d0003cc6b6d"],"name":"temp_keuken","sw_version":"Zigbee2mqtt 1.12.0","model":"MiJia temperature & humidity sensor (WSDCGQ01LM)","manufacturer":"Xiaomi"},"availability_topic":"zigbee2mqtt/bridge/state"}'
2020-03-20 20:07:01 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on homeassistant/sensor/0xccccccfffec13ab3/battery/config (retained): b'{"unit_of_measurement":"%","device_class":"battery","value_template":"{{ value_json.battery }}","state_topic":"zigbee2mqtt/ikeapirkeuken","json_attributes_topic":"zigbee2mqtt/ikeapirkeuken","name":"ikeapirkeuken_battery","unique_id":"0xccccccfffec13ab3_battery_zigbee2mqtt","device":{"identifiers":["zigbee2mqtt_0xccccccfffec13ab3"],"name":"ikeapirkeuken","sw_version":"Zigbee2mqtt 1.12.0","model":"TRADFRI motion sensor (E1525/E1745)","manufacturer":"IKEA"},"availability_topic":"zigbee2mqtt/bridge/state"}'
