I have 4 TRV (Eurotronic Spirit Zigbee), connected via zigbee2mqtt --> mqtt broker --> home assistant.
Now I want one TRV1 to be the “master”: physical modifications on TRV1 should be duplicated on TRV2, TRV3 and TRV4.
In example:
- raise temp (not with the app, but by touching the buttons on the TRV) on TRV1 will raise temp on other TRV’s
- set TRF to “off” --> same on other TRV’s etc…
When I manipulate temperature buttons on my TRV1, I receive messages like
Client mosq-NIZNJv1orsqEb3jAbS received PUBLISH (d0, q0, r0, m0, 'zigbee2mqtt/0x00158d0001ff8bca', ... (373 bytes))
{"pi_heating_demand":1,"linkquality":102,"local_temperature":23.5,"occupied_heating_setpoint":18,"unoccupied_heating_setpoint":16,"current_heating_setpoint":21,"eurotronic_error_status":0,"eurotronic_host_flags":{"mirror_display":false,"boost":false,"window_open":false,"child_protection":false},"system_mode":"auto","eurotronic_system_mode":1,"battery":30,"battery_low":0}
How can I use the value of
and duplicate it to other TRV’s?
I already created an automation like
- alias: radiator_gang_set_temperature
initial_state: 'on'
platform: mqtt
topic: zigbee2mqtt/0x00158d0001ff8bca/set/current_heating_setpoint
# radiator gang
# - service: mqtt.publish
# data_template:
# topic: zigbee2mqtt/0x00158d0001ff8bca/set/current_heating_setpoint
# payload: '{{ trigger.payload }}'
# radiator badkamer
data_template:
topic: zigbee2mqtt/0x00158d0001ff904f/set/current_heating_setpoint
# radiator slaapkamer
data_template:
topic: zigbee2mqtt/0x00158d00053d4000/set/current_heating_setpoint
# radiator woonkamer
data_template:
topic: zigbee2mqtt/0x00158d00053d404d/set/current_heating_setpoint
and this works if I use the app for setting the temp, based on
platform: mqtt
However, If I manipulate the physical buttons on the TRV, I do NOT receive the same trigger. I only receive messages like
Client mosq-NIZNJv1orsqEb3jAbS received PUBLISH (d0, q0, r0, m0, 'zigbee2mqtt/0x00158d0001ff8bca', ... (372 bytes))
{"pi_heating_demand":1,"linkquality":94,"local_temperature":22.5,"occupied_heating_setpoint":18,"unoccupied_heating_setpoint":16,"current_heating_setpoint":18,"eurotronic_error_status":0,"eurotronic_host_flags":{"mirror_display":false,"boost":false,"window_open":false,"child_protection":false},"system_mode":"auto","eurotronic_system_mode":1,"battery":30,"battery_low":0}
So I probably need a template that extracts the value of
from the above messange, so that I can use it in my automation
data_template:
But I don’t now how to extract the value.
Any help appreciated!
Kind regards,
Bart
