Hi All
I am a newbie, so please excuse the question.
I have set up an automation , so that when I press an IKEA Trafidi button, my TV turns on and switches to Netflix.
For some reason I can’t get the ‘enter’ command to execute so that my Netflix account is selected.
Can someone advise please
It might be a delay is needed between the commands. I have had issues with Home Assistant and needing to add delays to Automations before sending the second command. You would need to time approx. how long it take for the Netflix screen to bring up the list of accounts and add that as a delay as an action then send the second command after that.
Many thanks Eric
So do I need to remove the ‘enter’ statement, from its current location, and set up a delay under the Netflix command?
Sorry for the basic question
Setup the netflix command, remove the enter command from that location.
Then add an action something like this:
Then add another action to send the enter command.
Got it, will give it a try.
Thanks very much for your help
