Hello, hope you are all well,
I need some help with reconfiguring my Nest Thermostat please.
I initially installed the learning thermostat 7-8 days ago, it worked just fine for 5 days and stopped working (reporting all values an unavailable).
After checking for a while I decided to delete everything and recreate the integration, since then I’ve created two brand new projects, then deleted them, waited 12 hours and create another fresh one. I followed (and now memorised) the whole process step by step and quite sure that I am not missing anything.
The problem is that when I enter the IDs and secret into Home Assistant, it connects nestservices.google.com
with the redirect URI of https://my.home-assistant.io/redirect/oauth
and the page displays “Something went wrong. Please try again in a few minutes” (I tried again after few minutes, hours, still the same). I got stuck at the same point with all three projects. I do remember to clear Application Secrets in between tries.
What can I do to troubleshoot this further ? Or any other recommendations you may have.
Many thanks.
