I had the plex component working over a year and a half ago, but had other issues and put home assistant aside. I’ve since come back committed and got a lot of stuff setup and working smoothly, but I am no longer able to get my Plex component to work.
I only have 1 server (on Nvidia Shield TV) with remote access, and working token (Plex sensor works great).
I have 2 error messages from my logs, but I’m confused by the issue and haven’t been able to find any helpful results when googling them. Anyone able to help shed some insight or suggestions? Both seem to indicate an SSL certificate issue… I have tried adjusting all the settings in plex.conf and have tried every combo but nothing has resulted in the component working.
Wed Apr 17 2019 14:30:20 GMT-0600 (Mountain Daylight Time)
Certificate did not match expected hostname: 192.168.86.111. Certificate: {'subject': ((('commonName', '*.9e7bf00db4a7436e8a9e945dde33fc3d.plex.direct'),),), 'subjectAltName': [('DNS', '*.9e7bf00db4a7436e8a9e945dde33fc3d.plex.direct')]}
Wed Apr 17 2019 14:30:21 GMT-0600 (Mountain Daylight Time)
Error while setting up platform plex
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 600, in urlopen
chunked=chunked)
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 343, in _make_request
self._validate_conn(conn)
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 839, in _validate_conn
conn.connect()
File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 364, in connect
_match_hostname(cert, self.assert_hostname or server_hostname)
File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 374, in _match_hostname
match_hostname(cert, asserted_hostname)
File "/usr/local/lib/python3.7/ssl.py", line 327, in match_hostname
% (hostname, dnsnames[0]))
ssl.SSLCertVerificationError: ("hostname '192.168.86.111' doesn't match '*.9e7bf00db4a7436e8a9e945dde33fc3d.plex.direct'",)
File "/usr/local/lib/python3.7/site-packages/requests/adapters.py", line 449, in send
timeout=timeout
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 638, in urlopen
_stacktrace=sys.exc_info()[2])
File "/usr/local/lib/python3.7/site-packages/urllib3/util/retry.py", line 398, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='192.168.86.111', port=32400): Max retries exceeded with url: / (Caused by SSLError(SSLCertVerificationError("hostname '192.168.86.111' doesn't match '*.9e7bf00db4a7436e8a9e945dde33fc3d.plex.direct'")))
File "/usr/local/lib/python3.7/site-packages/homeassistant/helpers/entity_platform.py", line 126, in _async_setup_platform
SLOW_SETUP_MAX_WAIT, loop=hass.loop)
File "/usr/local/lib/python3.7/asyncio/tasks.py", line 416, in wait_for
return fut.result()
File "/usr/local/lib/python3.7/site-packages/homeassistant/components/plex/media_player.py", line 96, in setup_platform
hass, config, add_entities_callback
File "/usr/local/lib/python3.7/site-packages/homeassistant/components/plex/media_player.py", line 115, in setup_plexserver
token, cert_session
File "/usr/local/lib/python3.7/site-packages/plexapi/server.py", line 102, in __init__
data = self.query(self.key, timeout=timeout)
File "/usr/local/lib/python3.7/site-packages/plexapi/server.py", line 341, in query
response = method(url, headers=headers, timeout=timeout, **kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 546, in get
return self.request('GET', url, **kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 533, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 646, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/adapters.py", line 514, in send
raise SSLError(e, request=request)
requests.exceptions.SSLError: HTTPSConnectionPool(host='192.168.86.111', port=32400): Max retries exceeded with url: / (Caused by SSLError(SSLCertVerificationError("hostname '192.168.86.111' doesn't match '*.9e7bf00db4a7436e8a9e945dde33fc3d.plex.direct'")))
Thank you!
