Ok, so ive been going at this one for a while now and cant find a clean, easy way to achieve this.
My setup is a esp32 controlling a relay. I have the esp32 connected and all GPIOs mapped and the relay can be controlled via on/off via an entity.
I need to trigger the relay for 5 seconds on an OFF event. So when I turn on a switch or button in my dashboard, the button should remain off, but the relay must pulse for 5 seconds.
When the switch is turned on, the button changes state to ON and the relay pulses twice for 5 seconds. (5 seconds active, off, 5 seconds active, off).
Is there an easy way to do this? esp32 yaml directly or going to need some fancy automations and helpers/timers etc?
Thanks its driving me nuts!
