On the config part i read:
“When the integration is configured, two entities will be created: a media_player and a remote . The remote allows you to send key commands to your TV with the remote.send_command service.”
And than some key’s i can use for commands.
But i have no idea how to set it up, if i search on ‘remote.send_command’ i get broadlink commands, but i thought the Sony integration just needed the ‘key’s’ to work as a command. Even then i have no idea how to call a command.
Does someone maybe has an example how i could use these ‘key’ commands( * Num1 * Num2 * ChannelUp) on a button card?
I do not have such a TV, but try opening your Developer Tools in the left sidebar, then select Services in the tabs and start typing remote in the service line.
Id love to see the configuration files if you’re still able to send them. Currently creating a remote for my Sony TV and could use all the help I can get.
Sorry late response, was out of it for a while.
Need to update them because of the borders HA has now added so will send the new files of they are ready.
PS, how can i get email notifications here? i never get any on a response
Hi Ricks88,
I’m a newbie in home assistant configuration, can you tell me how you use your yaml file ?
Is it code you add to an existing file or is it a file called by another file ?
Thank you for any help and for the job you’ve done for this remote.
Thanks for your answer.
I’ve been working on it all day long and I can’t get it to display the remote.
I’ve installed HACS, button-card and vertical-stack-in-card but nothing helps something isn’t working, sometimes I get the code with unrecognized button-card but I often just get something that doesn’t display.
Any idea ?
This is what I get :
