Hi guys, my name is Sebastian.
I am new to this community and need some help with my smarthome. We bought this house from an IT-specialist and it has A LOT of smarthome features i am trying to figure out… (mainly KNX and EnOcean) Everything is connected to two PIs running homebridge and then implemented into Apple HomeKit. Works really well… The main reason for me to mess with this system is, that i am using Android and Windows devices and my wife uses IOS. So i set up yet another Pi running Homeassistant which is then connected to my android. So far this works great and i am able to controll some KNX devices from all sides (Android, Homeassistant and IOS). I am not willing to mess up the existing system (Homebridges) as of yet, scince i am afraight i might end up with a big mess
Right now i am trying to set up the EnOcean devices but so far i had no success. Here is the hardware-setup as far as i know:
We have lights and blinds in every room connected to the eltako fsr14-4x. These are then connected to the FAM 14 which got an antenna mounted somewhere behind the walls (in the centre of the building). The switches in the rooms are PTM215 DB. The Eltako devices are connectet to the homebridge-PIs via an USB-Gateway.
My plan:
I bought the EnOcean USB-300 controller which i hooked up to my HA-Pi. The plan is to be able to send EnOcean-Actions from Homeassistant to this USB-300 which then sends the actions to the FAM 14 antenna. Scince the Homebridges are still connected to the IOS-devices, it should all sync up.
First question is: How do i setup the EnOcean Hub correctly? As far as i know i first need to type in the port of the USB-300 controller. But i have no clue how i can find this out.
Then i need the device_ID which i am not able to find either.
Thank you so much in advance!
Sebastian
