Hello all,
I just installed HA. Had a hard time loading the page. but once it loaded it gave me the following prompt. (see below)
What to do now?
[supervisor.docker.interface] Can't install ghcr.io/home-assistant/raspberrypi3-64-homeassistant:2024.6.1: 404 Client Error for http+docker://localhost/v1.44/images/ghcr.io/home-assistant/raspberrypi3-64-homeassistant:2024.6.1/json: Not Found ("No such image: ghcr.io/home-assistant/raspberrypi3-64-homeassistant:2024.6.1")
[supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
[supervisor.docker.interface] Updating image ghcr.io/home-assistant/raspberrypi3-64-homeassistant:landingpage to ghcr.io/home-assistant/raspberrypi3-64-homeassistant:2024.6.1
[supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/raspberrypi3-64-homeassistant with tag 2024.6.1.
