Hi there.
I’m new to community and relatively new to HA. Was using OpenHab for couple years now, but wanted to try something else, so here I am.
So lets cut to the chase.
I need someone to help with two rules that I can not figure out for myself.
The first is for my heating system. I have two switches that each control a relay and I need to make three state switches from them.
The idea is if one relay is on then heating is on “Comfort” mode, if other relay is on then “Eco” mode and if both them are off, then heating is on “Auto” mode. The hardware works and I can control Heating system with two switches, but that is just not convinient.
I would like to combine thouse in one switch.
As I could not find out how to do that I made “input_select” entity with thouse 3 selections that is working. But I can not get the imput select to control my automations
So, here is my input_select
input_select:
apkures_temp:
options:
- Eco
- Auto
- Comfort
initial: Auto
icon: mdi:nest-thermostat
And it seams to work fine.
The problem is wit my automation
- alias: 'Apkures temperatūra_Eco'
platform: state
entity_id: input_select.apkures_temp
to: 'Eco'
- service: switch.turn_on
entity_id: switch.katls_2_1
- service: switch.turn_off
entity_id: switch.katls_2_2
- alias: 'Apkures temperatūra_Auto'
platform: state
to: 'Auto'
entity_id:
- switch.katls_2_1
- switch.katls_2_2
- alias: 'Apkures temperatūra_comfort'
platform: state
to: 'Comfort'
I got no errors, but input select does not change switches, hope that someone sees the problem.
So the next should be easy but I can not find any example of this.
I got a light for my unoccupied loft (I hope that this is not a wrong word) and switch for it is next to one for my corridor. Wery often when friends come over they turn on wrong light and I only realize it in next day because the only way to see this is from UI or outside windows.
With openhab, I had a simple rule that notifies me if this light was on for one hour so I can turn it off if it was turned on by accident or let it stay if I was doing something there. Sadly I could not find any example of similar rule please let me know where I can find an example for this.
Thanks and sorry for my bad English and that Im not abble to get formating to work.
