Need help with speakers on home assistant machines
I can not get a grip on installing speakers through out the house for Home Assistant. My setup is Home Assistant is installed on a raspberry pi 4 with 8 GB of ram, which is located in my Office. I use a raspberry pi 3B located in the living room to view homeassistant:8123 with the pi 3B browser and my windows 10 office computer. The only way to play sound with both computers is through media using browser. I have automatons which use tts, but the only way to play the sound is through mpd speaker on the home assistant. There is several topics in this forum on speakers, but each say install speaker. What does that mean. I am new to home assistant and very confused! Could someone please help me with the speaker problem.
I have not watched this yet but hopefully it will answer your questions:
I will watch again to check if I missed something but, I did not learn how to install speaker on machine that home assistant is not installed on. I can play local sounds or music on each machine but, not from HA machine to living room machine. Thanks for the tip.
You would need a media player supported by home assistant. Either software or hardware.
https://www.home-assistant.io/integrations/#media-player
