Thu Nov 14 2019 10:37:30 GMT+0200 (South Africa Standard Time)
Component error: ssl_key - Integration ‘ssl_key’ not found. Component error: ssl_certificate - Integration ‘ssl_certificate’ not found.
Please read the sticky post on how to ask a good question. An error message alone is rarely enough to allow anybody to effectively help you.
That said, it’s 100% likely that your problem is with indenting of the http: section of your configuration. See the documentation for how it should look, and if that doesn’t solve it please share your configuration - correctly formatted - so we can help you.
