Need help with tracking my washing machine status
I’m trying to get a project done for my wife who wanted to be alerted when our dumb-washer was completed its cycle. I bout a Wemo Insight plug and have been tracking the last few cycles the washer has gone through and have the amperate associated which each part of the cycle. I am now trying to turn this into an automation, but am having very little luck figuring out how.
My thought was to create a input_select list, and have that list selection appear as a text (similar to a timer automation) but I cannot get that to show on in the area I want. From there, my plan was to create an automation based on the previous washer state, and the current amperage that would give the cycle status. I could then set up a notify prompt for when the washer has turned off from an active load.
This is what I was trying to display:
input_select.yaml
washer_tatus:
  options:
    - Washer Off
    - Filling (First)
    - Cleaning
    - Draining (First)
    - Spin Cycle
    - Filling (Second)
    - Rinse Cycle
    - Final Drain
    - Final Spin
  initial: Off
  icon: mdi:washing-machine
this is my sensor entry
  sensors:
    washer_status:
      friendly_name: 'Washer Status'
      value_template: '{{ options.input_select.washerstatus.options }}'
And finally, my group entry for trying to display the status.
Laundry Room:
   entities:
    - switch.laundry_room
    - sensor.washer_current_power
    - sensor.washer_status
Please help!
Thanks,
I saw this linked from a Reddit post, maybe it’ll help you. It looks to be pretty much what you’re after.
I know is not an automation, but if its so important to know the status why now a simple camera?
Thanks for the link @Tinkerer that did help a bit. I’m stuck now at the point i’m getting errors in my log that I do not understand. Here is what I have for my automation file:
- alias: Set Washer Status to Idle
      value_template: '{{ states.switch.wemo_insight.attributes.current_power_w < 5}}'
#      below: 5
  condition:
    condition: state
    entity_id: switch.wemo_insight
    state: on
    - service: input_select.select_option
        entity_id: input_select.washer_status
        option: Idle
- alias: Set Washer Status to Off
      value_template: '{{ states.switch.wemo_insight.attributes.current_power_w < 5 }}'
#      below: 5
  condition:
    condition: state
    state: off
        option: Power and Wemo Off
- alias: Set Washer Status to First Fill
#      below: 5
  condition:
    condition: and
    conditions:
      - condition: template
        value_template: '{{ states.switch.wemo_insight.attributes.current_power_w}}'
        above: 6
        value_template: '{{ states.switch.wemo_insight.attributes.current_power_w }}'
        below: 20
        option: Filling (First)
- alias: Set Washer Status to Cleaning
#      below: 5
  condition:
    condition: and
    conditions:
        above: 25
        below: 250
        option: Cleaning
- alias: Set Washer Status to First Drain
#      below: 5
  condition:
    condition: and
    conditions:
        above: 15
        below: 75
        option: Draining (First)
- alias: Set Washer Status to Spin Cycle
#      below: 5
  condition:
    condition: and
    conditions:
        above: 280
        below: 580
        option: Spin Cycle
- alias: Set Washer Status to Second Fill
#      below: 5
  condition:
    condition: and
    conditions:
        above: 6
        below: 20
      - condition: state
        state: Spin Cycle
        option: Filling (Second)
My input_select.yaml is:
 washer_status:
  options:
    - Idle
    - Filling (First)
    - Cleaning
    - Draining (First)
    - Spin Cycle
    - Filling (Second)
    - Rinse Cycle
    - Final Drain
    - Final Spin
    - Power and Wemo Off
  initial: Power and Wemo Off
And my sensor looks like this:
  sensors:
    washer_status:
      value_template: '{{ states.input_select.washer_status.state }}'
But, on boot i’m getting these errors:
17-04-30 17:52:23 ERROR (MainThread) [homeassistant.config] Invalid config for [automation]: extra keys not allowed @ data['condition'][0]['state']. Got None
not a valid value for dictionary value @ data['condition'][0]['condition']. Got None. (See /home/homeassistant/.homeassistant/configuration.yaml, line 93). Please check the docs at https://home-assistant.io/components/automation/
17-04-30 17:52:23 ERROR (MainThread) [homeassistant.config] Invalid config for [automation]: not a valid value for dictionary value @ data['condition'][0]['conditions'][0]['condition']. Got None
required key not provided @ data['condition'][0]['conditions'][0]['entity_id']. Got None. (See /home/homeassistant/.homeassistant/configuration.yaml, line 93). Please check the docs at https://home-assistant.io/components/automation/
Not sure what that exactly means…
For a start, your triggers are missing anything to trigger at. All those below values you commented out are important - there needs to be something here to trigger at.
Given that you’re attempting to map every single step of your washing machine’s processes, this is likely to be challenging. I’d highly recommend you look to simplify it, particularly as you’re really only after the goal of notifying when it completes. As a starting point, I’d recommend an automation that simply maps the transition from idle, to operational, to off. Then once you’ve got that working, that’s when you look to make it more complicated.
See if this thread helps you out at all.
Hello again,
Played around with this and did a little more digging. I finally have the status changing between me turning off the Wemo insight, and turning it on and having ~ 3 amps running idle. I’ll work on the rest of the logic next but that won’t be for a day or so (no more laundry to do, lol)
Here is the code for anyone else whom it may help. I’ll update when completed.
- alias: 'Washer Idle'
      platform: numeric_state
      value_template: '{{ state.attributes.current_power_w }}'
      above: 1
      below: 5
  condition:
    condition: state
    entity_id: 'switch.wemo_insight'
    state: 'on'
        option: Idle
- alias: 'Washer Off'
      platform: state
      state: 'off'
  condition:
    condition: state
    state: 'off'
You might have a look at my implementation. See: Action when laundry is done
Maybe a sensor would be a more feasible choice? What’s the point of using an input_select?
Here are 2 code example that might help you
Sensor.yaml:
  day_night:
    friendly_name: 'День и ночь'
    value_template: >-
        {%- if now().hour >= 20 and now().hour < 23 %}
            Evening
        {%- elif now().hour >= 23 and now().hour < 24 %}
            Nightfall
        {%  elif now().hour >= 0 and now().hour < 6 %}
            Night
        {%  elif now().hour >= 6 and now().hour < 8 %}
            Cockcrow
        {% else %}
            Day
        {%- endif %}
Example 2
  light_level:
    friendly_name: 'Освещенность'
    value_template: >-
        {%- if states('sensor.flower_zal_light_intensity') | int <= 100 %}
            Dark
        {%- elif states('sensor.flower_zal_light_intensity') | int > 100 and states('sensor.flower_zal_light_intensity') | int < 650 %}
            Low light
        {% else %}
            Bright
        {%- endif %}
Here’s how I did it with Aeotec Smart Switches; see if this helps:
Hi
Thanks @rpitera and @fversteegen for the help. I now i’m late in posting this, but I only got around to fixing it recently.
First and foremost; an updated backstory:
I wanted to track the wash cycles of my washing machine using a Wemo Insight. The Wemo insight is a 15amp wifi switch that also has power/current monitoring capabilities. By monitoring the power usage of the washer, I could send a notification to select devices when the wash load was complete.
At first, I tried to solve this tracking the filling, drain, spin, rinse, cycle of the dryer based on the ‘power’ (in watts) of the washer, and creating input_booleans. This did not work too well, as sometimes my washers current would drop down for some time in between readings of the power, and cause false flags for the input_booleans.
after reading @fversteegen and @rpitera 's replies, I ended up with a mixture of their working examples and created this one. I will end up tweaking it over time, but for now it works.
sensors.yaml
  sensors:
    washer_status:
  sensors:
    washer_current_power:
      friendly_name: 'Washing Machine Power'
      value_template: '{{ states.switch.wemoinsight.attributes.current_power_w }}'
      unit_of_measurement: 'W'
- platform: statistics
  name: 'Washer Average Watts'
  entity_id: sensor.washer_current_power
  sampling_size: 6
The first one is just a simple text sensor to read out on my card in the HA GUI to show the washer status. Those are in my input_select.yaml file (see below).
The second sensor is a live display of the current being used by the washing machine. Having a sensor added allowed me to see and graph in HA the power cycle of a wash load.
The third sensor is a statistics sensor to track a running average of the washing machine. This eliminated the times when my washer would change power states mid cycle due. The running average took longer to change, and hence worked better.
input_select.yaml
washer_status:
  options:
    - Idle
    - Cleaning
    - Power Off
  initial: Power Off
Pretty self explanatory.
automations.yaml
- id: 'washer_idle'
    - entity_id: binary_sensor.washerpower_current
      platform: state
      to: 'off'
      for:
        minutes: 2
  condition:
    condition: and
    conditions:
      - condition: state
        entity_id: 'switch.wemoinsight'
        state: 'on'
        option: Idle
    - service: notify.motog
        message: Wash cycle complete; enjoy the clean clothes!
        title: Wash Cycle Complete
    - service: notify.ios_ar_iphone
    - service: tts.google_say
      entity_id: media_player.man_cave_chromecast
        message: "Wash cycle complete; enjoy the clean clothes!"
- id: 'washer_running'
  alias: 'Washer Running'
    - entity_id: sensor.washer_average_watts_mean
      above: 6
  condition:
    condition: and
    conditions:
      - condition: state
        state: 'on'
        option: Cleaning
- id: 'washer_off'
  alias: 'Washer and Wemo Off'
    - entity_id: switch.wemoinsight
      platform: state
      to: 'off'
        option: Power Off
- id: 'washer_wemo_auto_off'
  alias: 'Power down Wemo after 1 hour of inactivity on washer'
      platform: state
      to: 'off'
      for:
        hours: 1
  condition:
    condition: and
    conditions:
      - condition: state
        state: 'on'
    - service: switch.turn_off
        option: Power Off
- id: 'washer_failed'
  alias: 'Washer has failed, something is wrong'
      platform: state
      to: 'off'
      for:
        minutes: 10
  condition:
    condition: and
    conditions:
      - condition: state
        state: 'on'
      - condition: state
        state: 'Cleaning'
        message: Wash cycle has failed; something is wrong!
        title: Wash Cycle Failed
    - service: notify.ios_dr_iphone
The automations.yaml is where the fun happens. washer_idle is the big one where as soon as the power of the washer drops to a certain level for 2 minutes; HA will send out a notification that the wash cycle is complete!
Thanks again to all for the help!
Alright, so I’m a little obsessed now. I ended up adding a counter to the status thanks to this post and can now track how long each wash cycle takes. By tracking the “triggering” event of a dummy input_boolean, you can measure time of the wash cycle itself.
input_boolean.yaml
  washer_stopwatch:
    initial: off
    icon: mdi:timelapse
sensor.yaml
  sensors:
    washer_stopwatch:
      friendly_name: "Wash Cycle Time"
      value_template: >
        {% if is_state('input_boolean.washer_stopwatch', 'off') %}
          {{ relative_time(states.automation.washer_running.attributes.last_triggered) }}
        {% elif is_state('sensor.washer_stopwatch', 'unknown') %}
          0 seconds
        {% else %}
          {{ states('sensor.washer_stopwatch') }}
        {% endif %}
This is the actual part that makes the magic happen thanks to @tboyce1.
automations.yaml
- id: 'washer_idle'
      platform: state
      to: 'off'
      for:
        minutes: 2
  condition:
    condition: and
    conditions:
      - condition: state
        state: 'on'
        option: Idle
    - service: input_boolean.turn_off
      entity_id: input_boolean.washer_stopwatch
      above: 6
  condition:
    condition: and
    conditions:
      - condition: state
        state: 'on'
        option: Cleaning
- id: 'washer_off'
      platform: state
      to: 'off'
        option: Power Off
      platform: state
      to: 'off'
      for:
        hours: 1
  condition:
    condition: and
    conditions:
      - condition: state
        state: 'on'
        option: Power Off
      platform: state
      to: 'off'
      for:
        minutes: 10
  condition:
    condition: and
    conditions:
      - condition: state
        state: 'on'
      - condition: state
        state: 'Cleaning'
        message: "Wash cycle failed."
Only slightly modified. When the washer_stopwatch dummy input_boolean is turned on (during the cleaning status), it starts registering the time from then to when it was last off (when the washer is idle). This will then display the time in minutes. This is reset upon the next wash cycle all thanks to the automation.
wash_cycle
So I’ve decided to take the plunge and get this going. I “borrowed” the bulk of your configs and modified them a bit for my use. Took me a bit to get it up and running but am now running into these errors and can’t seem to figure out where I made a wrong turn. I’m hoping you and the others might be able to help me out.
Here are the errors I get:
2017-11-09 13:34:39 ERROR (MainThread) [homeassistant.helpers.entity] Update for sensor.washer_stopwatch fails
File “/srv/homeassistant/homeassistant_venv/lib/python3.6/site-packages/homeassistant/helpers/entity.py”, line 204, in async_update_ha_state
yield from self.async_device_update()
File “/srv/homeassistant/homeassistant_venv/lib/python3.6/site-packages/homeassistant/helpers/entity.py”, line 307, in async_device_update
yield from self.async_update()
File “/usr/local/lib/python3.6/asyncio/coroutines.py”, line 210, in coro
res = func(*args, **kw)
File “/srv/homeassistant/homeassistant_venv/lib/python3.6/site-packages/homeassistant/components/sensor/template.py”, line 155, in async_update
self._state = self._template.async_render()
File “/srv/homeassistant/homeassistant_venv/lib/python3.6/site-packages/homeassistant/helpers/template.py”, line 116, in async_render
return self._compiled.render(kwargs).strip()
File “/srv/homeassistant/homeassistant_venv/lib/python3.6/site-packages/jinja2/asyncsupport.py”, line 76, in render
return original_render(self, *args, **kwargs)
File “/srv/homeassistant/homeassistant_venv/lib/python3.6/site-packages/jinja2/environment.py”, line 1008, in render
return self.environment.handle_exception(exc_info, True)
File “/srv/homeassistant/homeassistant_venv/lib/python3.6/site-packages/jinja2/environment.py”, line 780, in handle_exception
reraise(exc_type, exc_value, tb)
File “/srv/homeassistant/homeassistant_venv/lib/python3.6/site-packages/jinja2/_compat.py”, line 37, in reraise
raise value.with_traceback(tb)
File “”, line 2, in top-level template code
File “/srv/homeassistant/homeassistant_venv/lib/python3.6/site-packages/jinja2/sandbox.py”, line 427, in call
return __context.call(__obj, *args, **kwargs)
File “/srv/homeassistant/homeassistant_venv/lib/python3.6/site-packages/homeassistant/util/dt.py”, line 192, in get_age
delta = now() - date
TypeError: unsupported operand type(s) for -: ‘datetime.datetime’ and ‘str’
2017-11-09 13:34:39 ERROR (MainThread) [homeassistant.components.sensor.template] Could not render template Washer Status: UndefinedError: ‘options’ is undefined
2017-11-09 13:34:40 ERROR (MainThread) [homeassistant.components.sensor.template] Could not render template Washer Status: UndefinedError: ‘options’ is undefined
Both errors just repeat and repeat and repeat and repeat.
And here are the relevant portions of code:
washer_status_is.yaml (input_select):
options:
  - Idle
  - Cleaning
  - Power Off
initial: Power Off
washer_stopwatch_ib.yaml (input_boolean):
name: Washer Stopwatch
initial: off
icon: mdi:timelapse
washer_stopwatch,yaml (sensor template):
  sensors:
    washer_stopwatch:
      friendly_name: 'Wash Cycle Time'
      value_template: >
          0 seconds
        {% else %}
          {{ state('sensor.washer_stopwatch') }}
        {% endif %}
washer_status.yaml (sensor template):
  sensors:
    washer_status:
      value_template: '{{ options.input_select.washer_status_is.options }}'
And finally, the 2 automations. (not using the power off or error ones just yet)
washer_idle.yaml :
  - entity_id: sensor.washer_current_consumption
    below: 1
    for:
      minutes: 3
condition:
  condition: and
  conditions:
    - condition: state
      entity_id: 'switch.washing_machine'
      state: 'on'
      entity_id: input_select.washer_status_is
      option: Idle
  - service: notify.HomeAssistantFE
      message: Wash cycle complete; put that shit in the dryer!
    entity_id: input_boolean.washer_stopwatch_ib
washer_running.yaml:
    above: 5
condition:
  condition: and
  conditions:
    - condition: state
      state: 'on'
      option: Cleaning
This is my first attempt at a more complex automation and templating so I expect that I’ve really screwed something up here; but for the life of me I just can’t figure it out. I’m hoping some fresh sets of eyes will be able to smack some sense into me.
Thanks!
This doesn’t look right to me, what are you trying to accomplish here?
Well there we have it. Fresh set of eyes does it.
Not sure where I got the ‘options.input_select.washer_status_is.options’ part (could have sworn I just copy pasted all of this but I guess I didn’t) but switching it to states.input_select.washer_status_is.state fixed it for me.
I followed your files and customized then for my solution.
But I cant get it to work…
Testing configuration at /home/homeassistant/.homeassistant
ERROR:homeassistant.config:Invalid config for [input_boolean]: expected a dictionary for dictionary value @ data['input_boolean']. Got [OrderedDict([('name', 'Washer Stopwatch'), ('initial', False), ('icon', 'mdi:timelapse')])]. (See ?, line ?). Please check the docs at https://home-assistant.io/components/input_boolean/
ERROR:homeassistant.setup:Setup failed for input_boolean: Invalid config.
ERROR:homeassistant.config:Invalid config for [input_select]: expected a dictionary for dictionary value @ data['input_select']. Got [OrderedDict([('washer_status', OrderedDict([('name', 'Washer Status'), ('options', ['Idle', 'Cleaning', 'Power Off']), ('initial', 'Power Off'), ('icon', 'mdi:washing-machine')]))])]. (See ?, line ?). Please check the docs at https://home-assistant.io/components/input_select/
ERROR:homeassistant.setup:Setup failed for input_select: Invalid config.
Failed config
  input_boolean:
    - icon: mdi:timelapse
      initial: False
  General Errors:
    - Setup failed for input_boolean: Invalid config.
    - Setup failed for input_select: Invalid config.
  input_select:
    - washer_status: [source /home/homeassistant/.homeassistant/input_selects/washer_status_is.yaml:1]
        initial: Power Off
        options: [source /home/homeassistant/.homeassistant/input_selects/washer_status_is.yaml:3]
          - Idle
          - Cleaning
          - Power Off
Successful config (partial)
  input_boolean:
  input_select:
Any ideas?
You aren’t identifying each entity correctly, just input them as:
input_boolean:
  washer_stopwatch:
    initial: off
    icon: mdi: timelapse
and:
input_select:
  washer_status:
    options:
      - Idle
      - Cleaning
      - Power Off
    initial: Power Off
Hi @derrick1985. It seems like automating the notification of washer/dryer status is a common desire! I found your post, and am attempting to adjust it for use with an Edimax switch which I bought a while back hoping to use the power monitoring aspect for this purpose, and am finally getting around to trying to implement it.
I’m stuck trying to understand what this binary_sensor is for. I can’t find any references as to how you defined it. Is it just part of your config that you just forgot to include in your post? Any reason you couldn’t just use a sensor.washer_average_watts_mean trigger with a below: 5 state?
Thanks for sharing your code!
Trying out a bit of this and the weird thing is I can take the code from the sensor and paste it into the template and it shows the time, but the sensor always says 0 seconds. I even cut out all the ifs just to see if it was dropping out to the static 0 for some odd reason. One minor piece driving me nuts.
    sensors:
      dryer_doortime:
        friendly_name: "Door Open Time"
        value_template: >
          {{ relative_time(states.automation.dryer_door_stopwatch.attributes.last_triggered) }}
Never used relative_time before, but just tested on 0.70.1 and I get nothing returned, even in the template…
Bug?
