I have several devices that I’ve flashed with ESPHome but have since been disconnected since I am either not using them or I am looking for a place to put them. I am running Home Assistant in Docker for background, trying to run on v 0.101.1
Lately, my Home Assistant logs have been flooded by these error messages and today I can’t get home assistant to start because of these failures. It doesn’t seem to ever time out and move on when an ESPHome device isn’t available. Here are the logs:
2019-11-05 13:11:12 INFO (MainThread) [homeassistant.components.esphome] Can't connect to ESPHome API for 192.168.1.129: Error connecting to ('192.168.1.129', 6053): [Errno 113] Connect call failed ('192.168.1.129', 6053),
2019-11-05 13:11:12 INFO (MainThread) [homeassistant.components.esphome] Can't connect to ESPHome API for 192.168.1.52: Error connecting to ('192.168.1.52', 6053): [Errno 113] Connect call failed ('192.168.1.52', 6053),
2019-11-05 13:11:12 INFO (MainThread) [homeassistant.components.esphome] Can't connect to ESPHome API for 192.168.1.49: Error connecting to ('192.168.1.49', 6053): [Errno 113] Connect call failed ('192.168.1.49', 6053),
2019-11-05 13:11:12 INFO (MainThread) [homeassistant.components.esphome] Can't connect to ESPHome API for 192.168.1.45: Error connecting to ('192.168.1.45', 6053): [Errno 113] Connect call failed ('192.168.1.45', 6053),
2019-11-05 13:11:12 INFO (MainThread) [homeassistant.components.esphome] Can't connect to ESPHome API for 192.168.1.50: Error connecting to ('192.168.1.50', 6053): [Errno 113] Connect call failed ('192.168.1.50', 6053),
2019-11-05 13:11:12 INFO (MainThread) [homeassistant.components.esphome] Trying to reconnect in 60 seconds,
2019-11-05 13:11:12 INFO (MainThread) [homeassistant.components.esphome] Can't connect to ESPHome API for 192.168.1.48: Error connecting to ('192.168.1.48', 6053): [Errno 113] Connect call failed ('192.168.1.48', 6053),
2019-11-05 13:11:12 INFO (MainThread) [homeassistant.components.esphome] Can't connect to ESPHome API for 192.168.1.51: Error connecting to ('192.168.1.51', 6053): [Errno 113] Connect call failed ('192.168.1.51', 6053),
2019-11-05 13:11:15 INFO (MainThread) [homeassistant.components.esphome] Can't connect to ESPHome API for 192.168.1.53: Error connecting to ('192.168.1.53', 6053): [Errno 113] Connect call failed ('192.168.1.53', 6053),
2019-11-05 13:11:15 INFO (MainThread) [homeassistant.components.esphome] Trying to reconnect in 60 seconds,
2019-11-05 13:11:15 INFO (MainThread) [homeassistant.components.esphome] Can't connect to ESPHome API for 192.168.1.55: Error connecting to ('192.168.1.55', 6053): [Errno 113] Connect call failed ('192.168.1.55', 6053),
2019-11-05 13:11:15 INFO (MainThread) [homeassistant.components.esphome] Can't connect to ESPHome API for 192.168.1.57: Error connecting to ('192.168.1.57', 6053): [Errno 113] Connect call failed ('192.168.1.57', 6053),
2019-11-05 13:11:15 INFO (MainThread) [homeassistant.components.esphome] Can't connect to ESPHome API for 192.168.1.56: Error connecting to ('192.168.1.56', 6053): [Errno 113] Connect call failed ('192.168.1.56', 6053),
2019-11-05 13:12:15 INFO (MainThread) [homeassistant.components.esphome] Can't connect to ESPHome API for sensornode_01.local: Error resolving IP address: [Errno -3] Try again,
2019-11-05 13:12:15 INFO (MainThread) [homeassistant.components.esphome] Can't connect to ESPHome API for sensornode_03.local: Error resolving IP address: [Errno -3] Try again,
2019-11-05 13:12:15 INFO (MainThread) [homeassistant.components.esphome] Trying to reconnect in 60 seconds,
2019-11-05 13:12:15 INFO (MainThread) [homeassistant.components.esphome] Can't connect to ESPHome API for 192.168.1.50: Error connecting to ('192.168.1.50', 6053): [Errno 113] Connect call failed ('192.168.1.50', 6053),
2019-11-05 13:12:15 INFO (MainThread) [homeassistant.components.esphome] Can't connect to ESPHome API for 192.168.1.45: Error connecting to ('192.168.1.45', 6053): [Errno 113] Connect call failed ('192.168.1.45', 6053),
2019-11-05 13:12:15 INFO (MainThread) [homeassistant.components.esphome] Can't connect to ESPHome API for 192.168.1.49: Error connecting to ('192.168.1.49', 6053): [Errno 113] Connect call failed ('192.168.1.49', 6053),
2019-11-05 13:12:15 INFO (MainThread) [homeassistant.components.esphome] Can't connect to ESPHome API for 192.168.1.52: Error connecting to ('192.168.1.52', 6053): [Errno 113] Connect call failed ('192.168.1.52', 6053),
2019-11-05 13:12:15 INFO (MainThread) [homeassistant.components.esphome] Can't connect to ESPHome API for 192.168.1.129: Error connecting to ('192.168.1.129', 6053): [Errno 113] Connect call failed ('192.168.1.129', 6053),
2019-11-05 13:12:15 INFO (MainThread) [homeassistant.components.esphome] Can't connect to ESPHome API for 192.168.1.51: Error connecting to ('192.168.1.51', 6053): [Errno 113] Connect call failed ('192.168.1.51', 6053),
2019-11-05 13:12:15 INFO (MainThread) [homeassistant.components.esphome] Can't connect to ESPHome API for 192.168.1.48: Error connecting to ('192.168.1.48', 6053): [Errno 113] Connect call failed ('192.168.1.48', 6053),
2019-11-05 13:12:18 INFO (MainThread) [homeassistant.components.esphome] Can't connect to ESPHome API for 192.168.1.53: Error connecting to ('192.168.1.53', 6053): [Errno 113] Connect call failed ('192.168.1.53', 6053),
2019-11-05 13:12:18 INFO (MainThread) [homeassistant.components.esphome] Trying to reconnect in 60 seconds,
2019-11-05 13:12:18 INFO (MainThread) [homeassistant.components.esphome] Can't connect to ESPHome API for 192.168.1.56: Error connecting to ('192.168.1.56', 6053): [Errno 113] Connect call failed ('192.168.1.56', 6053),
2019-11-05 13:12:18 INFO (MainThread) [homeassistant.components.esphome] Can't connect to ESPHome API for 192.168.1.57: Error connecting to ('192.168.1.57', 6053): [Errno 113] Connect call failed ('192.168.1.57', 6053),
2019-11-05 13:12:18 INFO (MainThread) [homeassistant.components.esphome] Can't connect to ESPHome API for 192.168.1.55: Error connecting to ('192.168.1.55', 6053): [Errno 113] Connect call failed ('192.168.1.55', 6053),
2019-11-05 13:13:18 INFO (MainThread) [homeassistant.components.esphome] Can't connect to ESPHome API for 192.168.1.129: Error connecting to ('192.168.1.129', 6053): [Errno 113] Connect call failed ('192.168.1.129', 6053),
2019-11-05 13:13:18 INFO (MainThread) [homeassistant.components.esphome] Can't connect to ESPHome API for 192.168.1.52: Error connecting to ('192.168.1.52', 6053): [Errno 113] Connect call failed ('192.168.1.52', 6053),
2019-11-05 13:13:18 INFO (MainThread) [homeassistant.components.esphome] Can't connect to ESPHome API for 192.168.1.49: Error connecting to ('192.168.1.49', 6053): [Errno 113] Connect call failed ('192.168.1.49', 6053),
2019-11-05 13:13:18 INFO (MainThread) [homeassistant.components.esphome] Can't connect to ESPHome API for 192.168.1.45: Error connecting to ('192.168.1.45', 6053): [Errno 113] Connect call failed ('192.168.1.45', 6053),
2019-11-05 13:13:18 INFO (MainThread) [homeassistant.components.esphome] Can't connect to ESPHome API for 192.168.1.50: Error connecting to ('192.168.1.50', 6053): [Errno 113] Connect call failed ('192.168.1.50', 6053),
2019-11-05 13:13:18 INFO (MainThread) [homeassistant.components.esphome] Trying to reconnect in 60 seconds,
2019-11-05 13:13:18 INFO (MainThread) [homeassistant.components.esphome] Can't connect to ESPHome API for 192.168.1.48: Error connecting to ('192.168.1.48', 6053): [Errno 113] Connect call failed ('192.168.1.48', 6053),
2019-11-05 13:13:18 INFO (MainThread) [homeassistant.components.esphome] Can't connect to ESPHome API for 192.168.1.51: Error connecting to ('192.168.1.51', 6053): [Errno 113] Connect call failed ('192.168.1.51', 6053),
2019-11-05 13:13:21 INFO (MainThread) [homeassistant.components.esphome] Can't connect to ESPHome API for 192.168.1.53: Error connecting to ('192.168.1.53', 6053): [Errno 113] Connect call failed ('192.168.1.53', 6053),
2019-11-05 13:13:21 INFO (MainThread) [homeassistant.components.esphome] Trying to reconnect in 60 seconds,
2019-11-05 13:13:21 INFO (MainThread) [homeassistant.components.esphome] Can't connect to ESPHome API for 192.168.1.55: Error connecting to ('192.168.1.55', 6053): [Errno 113] Connect call failed ('192.168.1.55', 6053),
2019-11-05 13:13:21 INFO (MainThread) [homeassistant.components.esphome] Can't connect to ESPHome API for 192.168.1.57: Error connecting to ('192.168.1.57', 6053): [Errno 113] Connect call failed ('192.168.1.57', 6053),
2019-11-05 13:13:21 INFO (MainThread) [homeassistant.components.esphome] Can't connect to ESPHome API for 192.168.1.56: Error connecting to ('192.168.1.56', 6053): [Errno 113] Connect call failed ('192.168.1.56', 6053),
2019-11-05 13:13:27 INFO (MainThread) [homeassistant.components.esphome] Can't connect to ESPHome API for sensornode_03.local: Error resolving IP address: [Errno -3] Try again,
2019-11-05 13:13:27 INFO (MainThread) [homeassistant.components.esphome] Trying to reconnect in 60 seconds,
2019-11-05 13:13:27 INFO (MainThread) [homeassistant.components.esphome] Can't connect to ESPHome API for sensornode_01.local: Error resolving IP address: [Errno -3] Try again,
2019-11-05 13:14:21 INFO (MainThread) [homeassistant.components.esphome] Can't connect to ESPHome API for 192.168.1.50: Error connecting to ('192.168.1.50', 6053): [Errno 113] Connect call failed ('192.168.1.50', 6053),
2019-11-05 13:14:21 INFO (MainThread) [homeassistant.components.esphome] Can't connect to ESPHome API for 192.168.1.45: Error connecting to ('192.168.1.45', 6053): [Errno 113] Connect call failed ('192.168.1.45', 6053),
2019-11-05 13:14:21 INFO (MainThread) [homeassistant.components.esphome] Can't connect to ESPHome API for 192.168.1.49: Error connecting to ('192.168.1.49', 6053): [Errno 113] Connect call failed ('192.168.1.49', 6053),
2019-11-05 13:14:21 INFO (MainThread) [homeassistant.components.esphome] Can't connect to ESPHome API for 192.168.1.52: Error connecting to ('192.168.1.52', 6053): [Errno 113] Connect call failed ('192.168.1.52', 6053),
2019-11-05 13:14:21 INFO (MainThread) [homeassistant.components.esphome] Can't connect to ESPHome API for 192.168.1.129: Error connecting to ('192.168.1.129', 6053): [Errno 113] Connect call failed ('192.168.1.129', 6053),
2019-11-05 13:14:21 INFO (MainThread) [homeassistant.components.esphome] Trying to reconnect in 60 seconds,
2019-11-05 13:14:22 INFO (MainThread) [homeassistant.components.esphome] Can't connect to ESPHome API for 192.168.1.51: Error connecting to ('192.168.1.51', 6053): [Errno 113] Connect call failed ('192.168.1.51', 6053),
2019-11-05 13:14:22 INFO (MainThread) [homeassistant.components.esphome] Can't connect to ESPHome API for 192.168.1.48: Error connecting to ('192.168.1.48', 6053): [Errno 113] Connect call failed ('192.168.1.48', 6053),
2019-11-05 13:14:22 INFO (MainThread) [homeassistant.components.esphome] Trying to reconnect in 60 seconds,
2019-11-05 13:14:24 INFO (MainThread) [homeassistant.components.esphome] Can't connect to ESPHome API for 192.168.1.53: Error connecting to ('192.168.1.53', 6053): [Errno 113] Connect call failed ('192.168.1.53', 6053),
2019-11-05 13:14:24 INFO (MainThread) [homeassistant.components.esphome] Trying to reconnect in 60 seconds,
2019-11-05 13:14:24 INFO (MainThread) [homeassistant.components.esphome] Can't connect to ESPHome API for 192.168.1.56: Error connecting to ('192.168.1.56', 6053): [Errno 113] Connect call failed ('192.168.1.56', 6053),
2019-11-05 13:14:24 INFO (MainThread) [homeassistant.components.esphome] Can't connect to ESPHome API for 192.168.1.55: Error connecting to ('192.168.1.55', 6053): [Errno 113] Connect call failed ('192.168.1.55', 6053),
2019-11-05 13:14:24 INFO (MainThread) [homeassistant.components.esphome] Can't connect to ESPHome API for 192.168.1.57: Error connecting to ('192.168.1.57', 6053): [Errno 113] Connect call failed ('192.168.1.57', 6053),
2019-11-05 13:14:39 INFO (MainThread) [homeassistant.components.esphome] Can't connect to ESPHome API for sensornode_03.local: Error resolving IP address: [Errno -3] Try again,
2019-11-05 13:14:39 INFO (MainThread) [homeassistant.components.esphome] Can't connect to ESPHome API for sensornode_01.local: Error resolving IP address: [Errno -3] Try again,
2019-11-05 13:14:39 INFO (MainThread) [homeassistant.components.esphome] Trying to reconnect in 60 seconds,
