Need help with Zigbee Gateway + zigbee2mqqt
So i have a small zigbee network with NOUS E1 Zigbee Gateway. Decided to try Home Assistant, but stuck on how to connect Home Assistant with NOUS Gateway. Home Assistant is running in the docker container. As i’ve understood i need to run zigbee2mqqt, but can’t find information on zigbee2mqqt + NOUS E1 Zigbee Gateway compatibility. Will it work? Or will it need some additional hardware?
In the final setup, i would like to keep using Tuya app in the phone, for controlling zigbee devices (this requires NOUS E1 Zigbee Gateway), also i want to have same devices in the Home Assistant and have also option to control them using HA+automations, not only Tuya app.
Will i need a 2nd coordinator for connecting it to the HW that runs HA container? Or can i somehow use one for everything?
I’ve tried to use “Tuya integration”, but for some reason i can only turn ON/OFF my zigbee smart sockets (Nous A1Z), but it does not show power consumption. As well HA says “Nous A1Z (unsupported)”.
But i do have same model smart plug (Nous A1Z) in other location where it is used with Sonoff zigbee dongle and it is working fine, reporting all data and power.
So it looks like i still need a solution for making it work in both HA (with power info) as well as Tuya app.
