I recently updated HomeAssistant to the latest version - Home Assistant 2023.6.1. After the update, the integration for Xiaomi Gateway 3 (custom component GitHub - AlexxIT/XiaomiGateway3: Control Zigbee, BLE and Mesh devices from Home Assistant with Xiaomi Gateway 3 on original firmware) became unavailable. So, I removed it and installed the “Xiomi Miio” integration for “Xiaomi Gateway 3”. In the settings, I provided my login, password, and country for connection via Xiaomi Miio Cloud. The devices were identified.
However, the gateway’s alarm_control_panel.shliuz_alarm status is “unavailable”. The controls for its “Armed” and “Disarmed” states are also unavailable.
Here are the entries from my Home Assistant Core Logs:
ERROR
Logger: miio.miioprotocol
Source: /usr/local/lib/python3.11/site-packages/miio/miioprotocol.py:255
First occurred: 14:49:45 (15 occurrences)
Last logged: 14:53:15
Got error when receiving: {'code': -9999, 'message': 'user ack timeout'}
Warning
Logger: homeassistant.helpers.entity
Source: helpers/entity.py:754
First occurred: 14:59:25 (43 occurrences)
Last logged: 15:09:55
Update of alarm_control_panel.gateway_alarm is taking over 10 seconds
Update of sensor.gateway_illuminance is taking over 10 seconds
I couldn’t find a solution to the problem on the Google forum. Could anyone help me figure out what’s going wrong?
Additionally:
The temperature/humidity sensors and leak detectors were identified and are working correctly. They are grouped under Xiaomi BLE.
Raspberry Pi 4 (rpi4-64)
lumi.gateway.mgl03
Software version: 1.5.5_0006
"home_assistant": {
"installation_type": "Home Assistant OS",
"version": "2023.6.1",
"dev": false,
"hassio": true,
"virtualenv": false,
"python_version": "3.11.3",
"docker": true,
"arch": "aarch64",
"timezone": "**REDACTED**",
"os_name": "Linux",
"os_version": "6.1.21-v8",
"supervisor": "2023.06.1",
"host_os": "Home Assistant OS 10.2",
"docker_version": "23.0.6",
"chassis": "embedded",
"run_as_root": true
"custom_components": {
"sonoff": {
"version": "3.3.1",
"requirements": [
"pycryptodome>=3.6.6"
"integration_manifest": {
"domain": "xiaomi_miio",
"name": "Xiaomi Miio",
"codeowners": [
"@rytilahti",
"@syssi",
"@starkillerOG"
"config_flow": true,
"documentation": "https://www.home-assistant.io/integrations/xiaomi_miio",
"iot_class": "local_polling",
"loggers": [
"micloud",
"miio"
"requirements": [
"construct==2.10.56",
"micloud==0.5",
"python-miio==0.5.12"
"zeroconf": [
"_miio._udp.local."
"is_built_in": true
"data": {
"config_entry": {
"entry_id": "**REDACTED**",
"version": 1,
"title": "\u0428\u043b\u044e\u0437",
"data": {
"config_flow_device": "gateway",
"host": "**REDACTED**",
"token": "**REDACTED**",
"model": "lumi.gateway.mgl03",
"mac": "**REDACTED**",
"cloud_username": "**REDACTED**",
"cloud_password": "**REDACTED**",
"cloud_country": "cn"
"options": {
"cloud_subdevices": true
"pref_disable_new_entities": false,
"pref_disable_polling": false,
"source": "user",
"unique_id": "**REDACTED**",
"disabled_by": null
