Need install help
i am new. installed HA from a video but i am missing ip address in wlp2so. i am hardwired so not sure what to do next. can you help me?
I think I understand what you are asking. First try http://homeassistant.local:8123
If that doesn’t work then you can either look in your router to see what DHCP assigned your device, or download something like https://angryip.org/ and scan your network to find the device IP. Hope that helps.
Hey there, when you are wired your ip should be shown with your lan adapter enp1so or similar. wlp is your wifi connection.
good catch
