I would like to have a skript that can handle the daily tts via Squeezebox. At the moment every tts event kills my playing Songs, and my playlist.
I would like to have the squeezebox to go on with music after the tts event. Any idea how to do that?
Not sure about squeezebox - but can you just write automation like
pasue the media.
call tts.
delay while it’s playing.
call play
Working on vlc at least
@moskovskiy82 I assume you “save” the current playing media_content_id for this to work?
Can you tell me how you do that?
No. It’s just a pause\play action. Ok got it - your playlist gets killed. I also have an input select which selects the radiostation. So calling something like this - might help?
data_template:
media_content_id: >
{% if is_state("input_select.radio_station", "RelaxFM") %}
http://ic2.101.ru:8000/v13
{%-elif is_state("input_select.radio_station", "RecordFM") %}
http://air2.radiorecord.ru:805/chil_320
{%-elif is_state("input_select.radio_station", "Classical") %}
http://174.36.206.197:8000/stream
{%-elif is_state("input_select.radio_station", "Lounge") %}
http://77.235.42.90:80/
{%-elif is_state("input_select.radio_station", "SmoothLounge") %}
http://sl128.hnux.com/
{% else %}
{% endif %}
media_content_type: 'music'
I suppose I could do that indeed since the only thing that needs to be resumed is a radio stream in my current setup. I happen to use input select for this too. I do have to enter a different delay for every tts and implement the “check if radio is playing and if is does, pauze the play” lines on every TTS automation/script but I’ll look into that.
