Need some assistance with automation script heat and window sensors
Hey fellow automaters!
I need a little help with some Yaml code I made in automations. I have automated heat system (wiser) in all rooms and in all rooms I have a window sensor to detect when we open a window to shut off the heating. I built it up like this:
4 triggers (opened, closed, increase in temp and decrease in temp.)
When window is opened it saves the current scene as a snapshot and turns down temperature. When window is close it activated the saved snapshop scene. When temperature is increased or decreased (ie. auto heat system turns down temp in the evening or up in the morning) while window is open, it overwrites the snapshot scene with the changed temperature and turns down heat again. This ensures both the new auto temp change is saved if it changes while window is open, but also the temperature is not set back to something high and set off heat while opened.
The problem is when the latter two triggers get triggered it then triggers itself a second time and makes a snapshot scene with the low temperature set byt itself making the automation in increase and decrease useless. I tried all kind of conditions but something keeps breaking or I get funky results. Any possible way to make a condition that fits, like ‘dont trigger if triggered by itself’?
Code:
alias: Living room open window
description: ""
  - type: opened
    platform: device
    device_id: 177ffbb82bde08b3014c9f846b45fe31
    entity_id: a5fc2fe0cbb75a9b034c6876f485b96f
    domain: binary_sensor
  - type: not_opened
    platform: device
  - platform: device
    device_id: ea20c20643849e5a4a810cceda4c8160
    domain: wiser
    entity_id: climate.wiser_living_room
    type: target_temperature_increased
  - platform: device
    domain: wiser
    type: target_temperature_decreased
condition: []
  - alias: Opening window
    if:
      - condition: trigger
        id:
          - opened
    then:
      - service: scene.create
          scene_id: living_room_scene
          snapshot_entities: climate.wiser_living_room
      - service: climate.set_temperature
          temperature: 5
  - if:
        id:
          - closed
    then:
      - service: scene.turn_on
        data: {}
          entity_id: scene.living_room_scene
    alias: Closing window
  - alias: Schedule fix when opened
    if:
      - condition: and
        conditions:
            id:
              - changed
          - type: is_open
            condition: device
            for:
              hours: 0
              minutes: 0
              seconds: 2
    then:
          temperature: 5
mode: queued
max: 10
To solve issues with recursion like this I usually create a third master control like a helper, a script or another automation that drives the execution of the automation that actually performs the actions.
I thought of something similar but I prefer to keep them in one automation / function to avoid too many.
But how do you get out of this issue with a control script?
