used
type: custom:button-card
entity: sensor.marquee_alerts
show_icon: false
variables:
count: >
[[[ return entity.state; ]]]
phrase: >
[[[ return (entity.state == 1) ? 'Alert: ' : 'Alerts: '; ]]]
marquee: >
[[[ return entity.attributes.marquee; ]]]
tap_action:
action: none
styles:
card:
- background-color: var(--background-color-off)
- color: var(--text-color-off)
- font-size: 20px
- font-weight: 400
- padding: 12px
name:
- justify-self: stretch
[[[ return `<div style='display: flex';>
<div>${variables.count} ${variables.phrase}</div>
<span style='width:100%;'>
<marquee>${variables.marquee}</marquee></span>`; ]]]
for years and dont think this ever showed incorrectly, but since it holds and unclosed div
, I figured I had to correct that.
However, both the original yaml above, and the latest version with all styling moved to the button-card config itself, show the count and phrase strings off center while the marquee is perfect as ever, or so it seems:
show_icon: false
variables:
count: >
phrase: >
[[[ return (entity.state === 1) ? 'Alert: ' : 'Alerts: '; ]]]
marquee: >
tap_action:
action: none
styles:
card:
- font-size: 20px
- font-weight: 400
- padding: 10px 12px
name:
- width: 100%
- display: flex
# - text-align: center
[[[ return `<div>${variables.count} ${variables.phrase}</div>
<div><span><marquee>${variables.marquee}</marquee></span></div>`; ]]]
As you can see I also tried the text-align: center
but it makes no difference at all. If I replace the marquee, which essentially is only returning a long string of text, with a long string of hardcoded text:
thisisatext thisisatext thisisatext thisisatext thisisatext
to do
<div><span'><marquee>thisisatext thisisatext thisisatext thisisatext thisisatext</marquee></span></div>`; ]]]
the button card changes height slightly and makes it all center nicely:
so, apparently, the marquee string makes the card use a higher height, causing the first part of the name (count_phrase) to show off center, but aligning the marquee correctly…
on this occasion the marquee string contains:
jaar getrouwd ♡♡
and these hearts apparently cause the issue… confess I never noticed that before, then again, it only happens once a year
long story short: why, and most importantly, how to fix?
please have a look, thanks!
