Need some help animated background
Can someone explain to me how it is possible that if I load hassio from home https://192...* me background does not work but if I load it from outside my home with duckdns it works well?
And I cant get back my hacs icon on the left.
What more information.
I installed animated background with hacs and it works fine on my computer and my hassio.
Now i did the same on the hassio from my brother true teamviewer and that works aswell if i look at it true duckdns but on his labtop at home it doesnot show up at all this happend after the update before it worked well to.
I also cant get the icon from hacs back on his labtop all of the other things from hacs working well on his labtop as minimediaplayer and the weahtercard and the themes.
I check again and again but the config on me hassio are the same as the config on his hassio.
I get very confused about this.
I tried to put back the old hacs but that doesnot change a thing.
I only differents between the 2 hassio is that on my brothers hassio are alote more intergrations. But i think that woundont make a differents.
we both use a raspberry pi 4
plaese assist thanks
