I’m just getting started with Home Assistant. I was wondering if someone could lend me a hand in writing Automation scripts to do the following:
I like to turn on Wemo Insight 1 when Wemo Insight 2 changes from Standby State to On State. This is to automate turning on my subwoofer in the other side of the room, when my AV receiver turns on.
I like to “toggle” Wemo Insight 3 at specific times (Mon, Wed, Fri @ 5am). I need to “toggle” because this is rebooting my AT&T modem. If I turn off and then turn on, I think I would lose the network connection in between…
You may want to try and do this in the Wemo app if available. If your router is down the off command will make it to the wemo switch however, the on command won’t reach it as their won’t be wifi available. The toggle option (as I under stand it) is used to change the state (off to on or on to off) when the state is not known.
