The automation should trigger only when the above input_boolean is true and a at specific time (here 09:00 AM).
Checking the syntax (hass --script check_config) throws errors.
condition: state
entity_id: input_boolean.auto_jalousien
state: true
-servcie: homeassistant.turn_on
entity_id:
switch.grosse_jalousie
switch.kleine_jalousie
But a script check give me this error i cannot interpret myself:General Errors:
- Error loading /home/homeassistant/.homeassistant/configuration.yaml: mapping values are not allowed here
in “/home/homeassistant/.homeassistant/automations.yaml”, line 26, column 15
