Hello all,
Could someone help me with coding or give me an example of how to code this:
Essentially I have 2 input sliders that control a set of blinds (the tilt portion of the blind). One goes from 0-460 and one goes from 0-700 (these numbers are essentially steps on the motor). How can I show those on a 100 percent scale though? 0 is fully closed in the down positions, 700 is in the middle of the blind positions which is 100% open (i.e. letting the most light in)
input_number:
stepper_control_right_test_blind:
name: Stepper Control Right Test Blind
min: 0
max: 460
step: 1
mode: slider
stepper_control_left_test_blind:
name: Stepper Control Left Test Blind
min: 0
max: 700
step: 1
mode: slider
I currently have these controlled by the standard cover (up/ stop/ down) lovelace card but I would like to also be able to control these by position (i.e. percent open). Can someone help me with this? (I’m not a programmer sadly).
Below is my current code for the first example 0-460 (so 920 would be closed in the up position)
I’m not sure that you all will even need the below but I have provided for others that may want to use it. (I didn’t develop it, I am a monkey when it comes to coding )
Thank you all for any help/ guidance you can provide
esphome:
platform: ESP32
board: nodemcu-32s
on_boot:
- priority: -200.0
then:
- stepper.report_position: # Set stepper to global variable
position: !lambda return id(stepper_motor_global);
- stepper.set_target: # Set stepper to global variable
target: !lambda return id(stepper_motor_global);
- if: # If blind is Closed
condition:
- lambda: 'return id(stepper_motor_global) == 0;'
then: # Publish state etc.
- cover.template.publish:
state: CLOSED
current_operation: IDLE
- if: # If blind is Open
condition:
- lambda: 'return id(stepper_motor_global) == id(endstop);'
state: OPEN
- if: # If blind is Neither
condition:
- lambda: 'return (id(stepper_motor_global) != 0) && (id(stepper_motor_global) != id(endstop));'
then: # # Publish state etc.
position: !lambda 'return (float(float(id(stepper_motor).current_position) / float(id(endstop))));'
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "NkblotNz0QL9TwPbE1tGMAcayC41bZqSRavwCtduSP4="
services:
- service: control_stepper
variables:
target: int
then:
target: !lambda 'return target;'
ota:
password: "1c32e35ea8e90d369b8feb7f8b204aef"
wifi:
ssid: !secret wifi_ssid
fast_connect: true
ap:
ssid: "DR-Blinds Fallback Hotspot"
password: "Fhm0gqd5qfc3"
captive_portal:
web_server:
port: 80
################################################################### STEPPER CHANGE (ENDSTOP)
globals:
- id: stepper_motor_global # Integer for storing the stepper position in case of reboot
type: int
restore_value: True
initial_value: '0'
- id: openclosed # Boolean to store OPEN/CLOSED state
type: bool
restore_value: True
initial_value: '0'
- id: endstop # Variable for storing ENDSTOP (how far to move stepper)
type: int
restore_value: True
initial_value: '460' # this is the max value # this is the max value
stepper:
- platform: a4988
step_pin: GPIO2
dir_pin:
number: GPIO4
inverted: true
sleep_pin:
number: GPIO5
inverted: true # inverted since using enable pin
max_speed: 250
################################################################### STEPPER CHANGE (TARGET)
cover:
name: Dining Room Blinds
open_action:
then:
- logger.log: "Opening"
target: 460
- while:
condition:
lambda: 'return id(stepper_motor).current_position < id(endstop);'
then:
current_operation: OPENING
- delay: 1000 ms
- globals.set: # Set global to current position
value: !lambda return id(stepper_motor).current_position;
- globals.set: # Set toggle to OPEN (No need for 'optimistic mode')
value: '1'
state: OPEN
close_action:
then:
- logger.log: "Closing"
- stepper.set_target: # Send stepper to 0
target: '0'
- while:
condition:
lambda: 'return id(stepper_motor).current_position > 0;'
then:
current_operation: CLOSING
- delay: 1000 ms
- globals.set: # Set toggle to CLOSED (No need for 'optimistic mode')
value: '0'
state: CLOSED
position_action:
then:
target: !lambda return int(id(endstop) * pos);
- while:
condition:
lambda: 'return id(stepper_motor).current_position != int(id(endstop) * pos);'
then:
- delay: 1000 ms
stop_action:
then:
target: !lambda return id(stepper_motor).current_position;
has_position: true
device_class: blind
switch:
name: Reset Dining Room Blinds
turn_on_action:
target: '920'
- wait_until:
lambda: 'return id(stepper_motor).current_position == 1500;'
- delay: 1s
target: '0'
value: '0'
state: CLOSED
- switch.turn_off: reset
- platform: restart
name: "Dining Room Blinds Reboot"
# Text sensors with general information.
text_sensor:
# Expose WiFi information as sensors.
- platform: wifi_info
ip_address:
name: Dining Room Blinds IP
ssid:
name: Dining Room Blinds SSID
# Sensors with general information.
# WiFi Signal sensor.
- platform: wifi_signal
name: Dining Room Blinds WiFi Signal
update_interval: 60s
