thanks @fanuch for replay to my post that was my question if my yaml configuration is wrong?
please excuse the way i write English is not my language
switch:
- platform: mqtt
command_topic: "cmnd/sonoff/power"
state_topic: "stat/sonoff/POWER"
qos: 1
payload_: "ON"
payload_off: "OFF"
retain: true
- platform: mqtt
command_topic: "cmnd/sonoff2/power"
state_topic: "stat/sonoff2/POWER"
qos: 1
payload_: "ON"
payload_off: "OFF"
retain: true
- platform: rpi_gpio
ports:
11: Fan Office
12: Light Desk
this is how is on my yamal file it was working fine on version 0.45 but after upgrade to 0.46.1 a get an error
and this is the log
2017-06-14 14:44:16 ERROR (MainThread) [homeassistant.setup] Error during setup of component rpi_gpio
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/setup.py", line 190, in _async_setup_component
component.setup, hass, processed_config)
File "/usr/lib/python3.4/asyncio/futures.py", line 388, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.4/asyncio/tasks.py", line 286, in _wakeup
value = future.result()
File "/usr/lib/python3.4/asyncio/futures.py", line 277, in result
raise self._exception
File "/usr/lib/python3.4/concurrent/futures/thread.py", line 54, in run
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/rpi_gpio.py", line 23, in setup
import RPi.GPIO as GPIO
ImportError: /home/homeassistant/.homeassistant/deps/RPi/GPIO.cpython-34m.so: file too short
2017-06-14 14:44:17 ERROR (MainThread) [homeassistant.setup] Unable to setup dependencies of switch.rpi_gpio. Setup failed for dependencies: rpi_gpio
2017-06-14 14:44:17 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform switch.rpi_gpio: Could not setup all dependencies.
2017-06-14 14:44:20 WARNING (MainThread) [homeassistant.components.automation.state] 'state' is deprecated. Please rename 'state' to 'to' in your configuration file.
2017-06-14 14:44:41 WARNING (Thread-7) [netdisco.ssdp] Found malformed XML at http://192.168.1.39:9080: status=ok
2017-06-14 14:44:44 ERROR (MainThread) [aiohttp.server] Error handling request
File "/srv/homeassistant/lib/python3.4/site-packages/requests/packages/urllib3/connection.py", line 141, in _new_conn
(self.host, self.port), self.timeout, **extra_kw)
File "/srv/homeassistant/lib/python3.4/site-packages/requests/packages/urllib3/util/connection.py", line 83, in create_connection
raise err
File "/srv/homeassistant/lib/python3.4/site-packages/requests/packages/urllib3/util/connection.py", line 73, in create_connection
sock.connect(sa)
OSError: [Errno 113] No route to host
File "/srv/homeassistant/lib/python3.4/site-packages/requests/packages/urllib3/connectionpool.py", line 600, in urlopen
chunked=chunked)
File "/srv/homeassistant/lib/python3.4/site-packages/requests/packages/urllib3/connectionpool.py", line 356, in _make_request
conn.request(method, url, **httplib_request_kw)
File "/usr/lib/python3.4/http/client.py", line 1090, in request
self._send_request(method, url, body, headers)
File "/usr/lib/python3.4/http/client.py", line 1128, in _send_request
self.endheaders(body)
File "/usr/lib/python3.4/http/client.py", line 1086, in endheaders
self._send_output(message_body)
File "/usr/lib/python3.4/http/client.py", line 924, in _send_output
self.send(msg)
File "/usr/lib/python3.4/http/client.py", line 859, in send
self.connect()
File "/srv/homeassistant/lib/python3.4/site-packages/requests/packages/urllib3/connection.py", line 166, in connect
conn = self._new_conn()
File "/srv/homeassistant/lib/python3.4/site-packages/requests/packages/urllib3/connection.py", line 150, in _new_conn
self, "Failed to establish a new connection: %s" % e)
requests.packages.urllib3.exceptions.NewConnectionError: <requests.packages.urllib3.connection.HTTPConnection object at 0x65187d50>: Failed to establish a new connection: [Errno 113] No route to host
File "/srv/homeassistant/lib/python3.4/site-packages/requests/adapters.py", line 438, in send
timeout=timeout
File "/srv/homeassistant/lib/python3.4/site-packages/requests/packages/urllib3/connectionpool.py", line 649, in urlopen
_stacktrace=sys.exc_info()[2])
File "/srv/homeassistant/lib/python3.4/site-packages/requests/packages/urllib3/util/retry.py", line 388, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
requests.packages.urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='192.168.1.151', port=8081): Max retries exceeded with url: / (Caused by NewConnectionError('<requests.packages.urllib3.connection.HTTPConnection object at 0x65187d50>: Failed to establish a new connection: [Errno 113] No route to host',))
File "/home/homeassistant/.homeassistant/deps/aiohttp/web_protocol.py", line 421, in start
resp = yield from self._request_handler(request)
File "/home/homeassistant/.homeassistant/deps/aiohttp/web.py", line 303, in _handle
resp = yield from handler(request)
File "/usr/lib/python3.4/asyncio/coroutines.py", line 143, in coro
res = yield from res
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/http/ban.py", line 58, in ban_middleware_handler
return (yield from handler(request))
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/http/__init__.py", line 424, in handle
result = yield from result
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/camera/__init__.py", line 249, in get
response = yield from self.handle(request, camera)
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/camera/__init__.py", line 269, in handle
image = yield from camera.async_camera_image()
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/camera/mjpeg.py", line 92, in async_camera_image
self.camera_image)
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/camera/mjpeg.py", line 120, in camera_image
req = requests.get(self._mjpeg_url, stream=True, timeout=10)
File "/srv/homeassistant/lib/python3.4/site-packages/requests/api.py", line 72, in get
return request('get', url, params=params, **kwargs)
File "/srv/homeassistant/lib/python3.4/site-packages/requests/api.py", line 58, in request
return session.request(method=method, url=url, **kwargs)
File "/srv/homeassistant/lib/python3.4/site-packages/requests/sessions.py", line 518, in request
resp = self.send(prep, **send_kwargs)
File "/srv/homeassistant/lib/python3.4/site-packages/requests/sessions.py", line 639, in send
r = adapter.send(request, **kwargs)
File "/srv/homeassistant/lib/python3.4/site-packages/requests/adapters.py", line 502, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPConnectionPool(host='192.168.1.151', port=8081): Max retries exceeded with url: / (Caused by NewConnectionError('<requests.packages.urllib3.connection.HTTPConnection object at 0x65187d50>: Failed to establish a new connection: [Errno 113] No route to host',))
raise err
sock.connect(sa)
chunked=chunked)
self.send(msg)
self.connect()
requests.packages.urllib3.exceptions.NewConnectionError: <requests.packages.urllib3.connection.HTTPConnection object at 0x6cbc9a70>: Failed to establish a new connection: [Errno 113] No route to host
timeout=timeout
requests.packages.urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='192.168.1.151', port=8081): Max retries exceeded with url: / (Caused by NewConnectionError('<requests.packages.urllib3.connection.HTTPConnection object at 0x6cbc9a70>: Failed to establish a new connection: [Errno 113] No route to host',))
self.camera_image)
requests.exceptions.ConnectionError: HTTPConnectionPool(host='192.168.1.151', port=8081): Max retries exceeded with url: / (Caused by NewConnectionError('<requests.packages.urllib3.connection.HTTPConnection object at 0x6cbc9a70>: Failed to establish a new connection: [Errno 113] No route to host',))
2017-06-14 14:44:47 ERROR (MainThread) [aiohttp.server] Error handling request
raise err
sock.connect(sa)
chunked=chunked)
self.send(msg)
self.connect()
requests.packages.urllib3.exceptions.NewConnectionError: <requests.packages.urllib3.connection.HTTPConnection object at 0x6a08f690>: Failed to establish a new connection: [Errno 113] No route to host
timeout=timeout
requests.packages.urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='192.168.1.151', port=8081): Max retries exceeded with url: / (Caused by NewConnectionError('<requests.packages.urllib3.connection.HTTPConnection object at 0x6a08f690>: Failed to establish a new connection: [Errno 113] No route to host',))
self.camera_image)
requests.exceptions.ConnectionError: HTTPConnectionPool(host='192.168.1.151', port=8081): Max retries exceeded with url: / (Caused by NewConnectionError('<requests.packages.urllib3.connection.HTTPConnection object at 0x6a08f690>: Failed to establish a new connection: [Errno 113] No route to host',))
