After the garage door has been open for 30 minutes, I want to send an alert that tells me how long the door has been open. I also want to send the same alert every 30 minutes until it is closed.
I want another alert when the door is finally closed(assuming it has been open at least 30 minutes).
Is this possible to do using the alert component? I have something setup using scripts and automation, but I would rather do it using this component since that would be a lot simpler. Any help would be appreciated.
It looks like the first part is possible. I’m starting to think the second part is not. Here’s the yaml code to do the first part:
alert:
garage_door:
name: 'The garage door has been open for "{{ relative_time(states.cover.garage_door.last_changed) }}". Message sent at "{{now().strftime("%H:%M:%S %Y-%m-%d")}}"'
entity_id: cover.garage_door
state: 'open'
repeat:
- 30
can_acknowledge: True
skip_first: True
notifiers:
- telegramBot
Ah my bad I was under the assumption your sensor also reports open states if it already is open. Because if so this would not work. The second part MAY be possible with a template sensor that you use for the alert instead of the cover.garage_door.
I’m not sure what you mean. The sensor does report open states. And this works just fine.
And for my second part, I think I will just put a feature request in for it. I’m thinking I’m not the only one that wants a notification when things go back to normal.
