arnaud.dlt
(Arnaud Dlt)
September 14, 2020, 8:35pm
1
Hi !
This is my first post I’m new with all of this, so I’m trying to configure a wifi contact sensor (working with smartlife) so when I open the door it’ll light on some bulb…
I’ve been looking for code here and there I found something that should work but it don’t…
Hope you’ll be able to help me…
So here you go with the configuration.yaml:
binary_sensor:
- platform: ping
host: 80.215.104.197
count: 1
scan_interval: 1
And with automations.yaml:
- alias: "Hallway Door Contact Sensor"
- entity_id: binary_sensor.ping_tuya_contact_door_sensor
platform: state
to: 'on'
condition:
condition: time
after: '19:00'
before: '08:00'
- device_id: 0396c9488491444fad2b9aae4a2dd56f
domain: light
entity_id: light.hue_color_lamp_2
type: turn_on
I’ve found the device’s IP address in the Smartlife app so I guess it’s the good one though I don’t see much activity when running ping with terminal…
Thanks in advance for the help !
Ninuss
(Ninus)
March 25, 2021, 8:42pm
2
It don’t work because the host indicated in your binary_sensor is the external ip of your router if you get this info from the SmartLife app.
You have to search the local ip of your door/window sensor in your router web page, assign a static ip to it, then use this static ip in your host parameter in your binary_sensor ping_tuya_contact_door_sensor.
I have done so and it worked.
The doow/window sensor is an ESP8266 chip that go in deep sleep mode after a magnet movement. The binary sensor that you have programmed is based on wifi response of the real sensor in the few seconds that it is waked up.
The only side effect is that if the door is open, the sensor change the state after near 4 seconds (for my system, the time to wake up and connect to wifi) and it change to the initial state after near 5 seconds (it go in deep sleep mode). So if the door is opened and closed quickly you can see only it was opened but not closed. An automation will work well only on open trigger.
migio
(Bruni Michele)
May 22, 2021, 1:17pm
3
Hi, I try with the same configuration just for the binary sensor.
My config:
binary_sensor:
- platform: ping
host: 192.168.1.107
count: 1
scan_interval: 1
I set the static ip address in the router (using the mac address visible in Smart Life app).
The sensor appear always “disconnected”
Any idea of how to troubleshooting that problem?
mcarty
(Arturo)
May 23, 2021, 8:42am
4
Are you able to ping from the command line?
mcarty
(Arturo)
May 23, 2021, 10:18am
6
Then probably that ip isnt assigned by the router. Check the ip at the smartlife app
migio
(Bruni Michele)
May 23, 2021, 10:50am
7
In smart Life I see my internet IP and not my local IP, there is any simple way to test any possible local ip? from 192.168.1.2 to 192.168.1.255
mcarty
(Arturo)
May 23, 2021, 11:15am
8
In windows i use zenmap, there are similar tools for any OS.
On linux you can:
nmap -sn 192.168.1.0/24
Or google Network Scanner Tools
migio
(Bruni Michele)
May 23, 2021, 11:49am
9
mmm, I make some tests but the status of binary_sensor
, platform: ping
is always connected
or disconnected
. I want to use this for door open
and door closed
. My doubt is: this sensor just tell me if sensor is online or offline?
mcarty
(Arturo)
May 23, 2021, 11:55am
10
Yes, your going abuot getting you binary sensor into HA in the wrong way.
If its Smartlife, you should be able to install the Tuya integration from Configuration > Integrations > Add Integration. This should then bring your contact door sensor into Home Assistant and you can then base your automations on this.
migio
(Bruni Michele)
May 23, 2021, 12:43pm
12
Thank you all. The problem is that Tuya integration don’t have the contact sensor ability…
Anyway, I found a HA to check all ip, just configure all ad with a script I create this config:
binary_sensor:
- platform: ping
host: 192.168.1.1
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.2
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.3
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.4
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.5
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.6
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.7
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.8
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.9
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.10
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.11
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.12
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.13
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.14
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.15
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.16
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.17
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.18
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.19
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.20
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.21
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.22
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.23
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.24
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.25
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.26
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.27
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.28
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.29
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.30
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.31
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.32
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.33
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.34
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.35
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.36
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.37
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.38
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.39
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.40
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.41
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.42
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.43
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.44
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.45
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.46
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.47
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.48
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.49
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.50
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.51
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.52
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.53
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.54
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.55
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.56
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.57
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.58
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.59
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.60
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.61
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.62
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.63
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.64
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.65
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.66
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.67
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.68
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.69
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.70
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.71
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.72
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.73
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.74
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.75
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.76
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.77
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.78
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.79
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.80
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.81
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.82
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.83
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.84
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.85
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.86
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.87
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.88
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.89
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.90
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.91
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.92
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.93
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.94
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.95
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.96
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.97
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.98
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.99
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.100
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.101
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.102
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.103
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.104
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.105
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.106
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.107
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.108
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.109
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.110
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.111
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.112
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.113
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.114
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.115
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.116
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.117
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.118
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.119
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.120
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.121
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.122
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.123
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.124
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.125
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.126
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.127
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.128
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.129
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.130
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.131
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.132
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.133
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.134
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.135
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.136
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.137
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.138
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.139
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.140
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.141
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.142
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.143
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.144
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.145
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.146
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.147
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.148
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.149
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.150
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.151
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.152
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.153
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.154
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.155
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.156
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.157
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.158
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.159
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.160
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.161
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.162
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.163
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.164
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.165
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.166
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.167
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.168
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.169
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.170
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.171
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.172
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.173
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.174
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.175
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.176
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.177
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.178
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.179
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.180
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.181
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.182
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.183
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.184
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.185
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.186
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.187
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.188
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.189
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.190
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.191
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.192
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.193
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.194
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.195
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.196
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.197
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.198
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.199
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.200
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.201
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.202
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.203
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.204
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.205
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.206
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.207
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.208
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.209
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.210
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.211
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.212
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.213
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.214
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.215
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.216
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.217
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.218
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.219
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.220
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.221
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.222
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.223
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.224
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.225
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.226
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.227
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.228
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.229
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.230
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.231
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.232
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.233
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.234
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.235
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.236
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.237
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.238
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.239
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.240
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.241
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.242
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.243
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.244
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.245
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.246
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.247
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.248
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.249
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.250
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.251
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.252
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.253
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.254
count: 1
scan_interval: 1
- platform: ping
host: 192.168.1.255
count: 1
scan_interval: 1
migio
(Bruni Michele)
May 23, 2021, 12:44pm
13
and you can view iwith this tab:
type: history-graph
entities:
- entity: binary_sensor.ping_ip_1
- entity: binary_sensor.ping_ip_2
- entity: binary_sensor.ping_ip_3
- entity: binary_sensor.ping_ip_4
- entity: binary_sensor.ping_ip_5
- entity: binary_sensor.ping_ip_6
- entity: binary_sensor.ping_ip_7
- entity: binary_sensor.ping_ip_8
- entity: binary_sensor.ping_ip_9
- entity: binary_sensor.ping_ip_10
- entity: binary_sensor.ping_ip_11
- entity: binary_sensor.ping_ip_12
- entity: binary_sensor.ping_ip_13
- entity: binary_sensor.ping_ip_14
- entity: binary_sensor.ping_ip_15
- entity: binary_sensor.ping_ip_16
- entity: binary_sensor.ping_ip_17
- entity: binary_sensor.ping_ip_18
- entity: binary_sensor.ping_ip_19
- entity: binary_sensor.ping_ip_20
- entity: binary_sensor.ping_ip_21
- entity: binary_sensor.ping_ip_22
- entity: binary_sensor.ping_ip_23
- entity: binary_sensor.ping_ip_24
- entity: binary_sensor.ping_ip_25
- entity: binary_sensor.ping_ip_26
- entity: binary_sensor.ping_ip_27
- entity: binary_sensor.ping_ip_28
- entity: binary_sensor.ping_ip_29
- entity: binary_sensor.ping_ip_30
- entity: binary_sensor.ping_ip_31
- entity: binary_sensor.ping_ip_32
- entity: binary_sensor.ping_ip_33
- entity: binary_sensor.ping_ip_34
- entity: binary_sensor.ping_ip_35
- entity: binary_sensor.ping_ip_36
- entity: binary_sensor.ping_ip_37
- entity: binary_sensor.ping_ip_38
- entity: binary_sensor.ping_ip_39
- entity: binary_sensor.ping_ip_40
- entity: binary_sensor.ping_ip_41
- entity: binary_sensor.ping_ip_42
- entity: binary_sensor.ping_ip_43
- entity: binary_sensor.ping_ip_44
- entity: binary_sensor.ping_ip_45
- entity: binary_sensor.ping_ip_46
- entity: binary_sensor.ping_ip_47
- entity: binary_sensor.ping_ip_48
- entity: binary_sensor.ping_ip_49
- entity: binary_sensor.ping_ip_50
- entity: binary_sensor.ping_ip_51
- entity: binary_sensor.ping_ip_52
- entity: binary_sensor.ping_ip_53
- entity: binary_sensor.ping_ip_54
- entity: binary_sensor.ping_ip_55
- entity: binary_sensor.ping_ip_56
- entity: binary_sensor.ping_ip_57
- entity: binary_sensor.ping_ip_58
- entity: binary_sensor.ping_ip_59
- entity: binary_sensor.ping_ip_60
- entity: binary_sensor.ping_ip_61
- entity: binary_sensor.ping_ip_62
- entity: binary_sensor.ping_ip_63
- entity: binary_sensor.ping_ip_64
- entity: binary_sensor.ping_ip_65
- entity: binary_sensor.ping_ip_66
- entity: binary_sensor.ping_ip_67
- entity: binary_sensor.ping_ip_68
- entity: binary_sensor.ping_ip_69
- entity: binary_sensor.ping_ip_70
- entity: binary_sensor.ping_ip_71
- entity: binary_sensor.ping_ip_72
- entity: binary_sensor.ping_ip_73
- entity: binary_sensor.ping_ip_74
- entity: binary_sensor.ping_ip_75
- entity: binary_sensor.ping_ip_76
- entity: binary_sensor.ping_ip_77
- entity: binary_sensor.ping_ip_78
- entity: binary_sensor.ping_ip_79
- entity: binary_sensor.ping_ip_80
- entity: binary_sensor.ping_ip_81
- entity: binary_sensor.ping_ip_82
- entity: binary_sensor.ping_ip_83
- entity: binary_sensor.ping_ip_84
- entity: binary_sensor.ping_ip_85
- entity: binary_sensor.ping_ip_86
- entity: binary_sensor.ping_ip_87
- entity: binary_sensor.ping_ip_88
- entity: binary_sensor.ping_ip_89
- entity: binary_sensor.ping_ip_90
- entity: binary_sensor.ping_ip_91
- entity: binary_sensor.ping_ip_92
- entity: binary_sensor.ping_ip_93
- entity: binary_sensor.ping_ip_94
- entity: binary_sensor.ping_ip_95
- entity: binary_sensor.ping_ip_96
- entity: binary_sensor.ping_ip_97
- entity: binary_sensor.ping_ip_98
- entity: binary_sensor.ping_ip_99
- entity: binary_sensor.ping_ip_100
- entity: binary_sensor.ping_ip_101
- entity: binary_sensor.ping_ip_102
- entity: binary_sensor.ping_ip_103
- entity: binary_sensor.ping_ip_104
- entity: binary_sensor.ping_ip_105
- entity: binary_sensor.ping_ip_106
- entity: binary_sensor.ping_ip_107
- entity: binary_sensor.ping_ip_108
- entity: binary_sensor.ping_ip_109
- entity: binary_sensor.ping_ip_110
- entity: binary_sensor.ping_ip_111
- entity: binary_sensor.ping_ip_112
- entity: binary_sensor.ping_ip_113
- entity: binary_sensor.ping_ip_114
- entity: binary_sensor.ping_ip_115
- entity: binary_sensor.ping_ip_116
- entity: binary_sensor.ping_ip_117
- entity: binary_sensor.ping_ip_118
- entity: binary_sensor.ping_ip_119
- entity: binary_sensor.ping_ip_120
- entity: binary_sensor.ping_ip_121
- entity: binary_sensor.ping_ip_122
- entity: binary_sensor.ping_ip_123
- entity: binary_sensor.ping_ip_124
- entity: binary_sensor.ping_ip_125
- entity: binary_sensor.ping_ip_126
- entity: binary_sensor.ping_ip_127
- entity: binary_sensor.ping_ip_128
- entity: binary_sensor.ping_ip_129
- entity: binary_sensor.ping_ip_130
- entity: binary_sensor.ping_ip_131
- entity: binary_sensor.ping_ip_132
- entity: binary_sensor.ping_ip_133
- entity: binary_sensor.ping_ip_134
- entity: binary_sensor.ping_ip_135
- entity: binary_sensor.ping_ip_136
- entity: binary_sensor.ping_ip_137
- entity: binary_sensor.ping_ip_138
- entity: binary_sensor.ping_ip_139
- entity: binary_sensor.ping_ip_140
- entity: binary_sensor.ping_ip_141
- entity: binary_sensor.ping_ip_142
- entity: binary_sensor.ping_ip_143
- entity: binary_sensor.ping_ip_144
- entity: binary_sensor.ping_ip_145
- entity: binary_sensor.ping_ip_146
- entity: binary_sensor.ping_ip_147
- entity: binary_sensor.ping_ip_148
- entity: binary_sensor.ping_ip_149
- entity: binary_sensor.ping_ip_150
- entity: binary_sensor.ping_ip_151
- entity: binary_sensor.ping_ip_152
- entity: binary_sensor.ping_ip_153
- entity: binary_sensor.ping_ip_154
- entity: binary_sensor.ping_ip_155
- entity: binary_sensor.ping_ip_156
- entity: binary_sensor.ping_ip_157
- entity: binary_sensor.ping_ip_158
- entity: binary_sensor.ping_ip_159
- entity: binary_sensor.ping_ip_160
- entity: binary_sensor.ping_ip_161
- entity: binary_sensor.ping_ip_162
- entity: binary_sensor.ping_ip_163
- entity: binary_sensor.ping_ip_164
- entity: binary_sensor.ping_ip_165
- entity: binary_sensor.ping_ip_166
- entity: binary_sensor.ping_ip_167
- entity: binary_sensor.ping_ip_168
- entity: binary_sensor.ping_ip_169
- entity: binary_sensor.ping_ip_170
- entity: binary_sensor.ping_ip_171
- entity: binary_sensor.ping_ip_172
- entity: binary_sensor.ping_ip_173
- entity: binary_sensor.ping_ip_174
- entity: binary_sensor.ping_ip_175
- entity: binary_sensor.ping_ip_176
- entity: binary_sensor.ping_ip_177
- entity: binary_sensor.ping_ip_178
- entity: binary_sensor.ping_ip_179
- entity: binary_sensor.ping_ip_180
- entity: binary_sensor.ping_ip_181
- entity: binary_sensor.ping_ip_182
- entity: binary_sensor.ping_ip_183
- entity: binary_sensor.ping_ip_184
- entity: binary_sensor.ping_ip_185
- entity: binary_sensor.ping_ip_186
- entity: binary_sensor.ping_ip_187
- entity: binary_sensor.ping_ip_188
- entity: binary_sensor.ping_ip_189
- entity: binary_sensor.ping_ip_190
- entity: binary_sensor.ping_ip_191
- entity: binary_sensor.ping_ip_192
- entity: binary_sensor.ping_ip_193
- entity: binary_sensor.ping_ip_194
- entity: binary_sensor.ping_ip_195
- entity: binary_sensor.ping_ip_196
- entity: binary_sensor.ping_ip_197
- entity: binary_sensor.ping_ip_198
- entity: binary_sensor.ping_ip_199
- entity: binary_sensor.ping_ip_200
- entity: binary_sensor.ping_ip_201
- entity: binary_sensor.ping_ip_202
- entity: binary_sensor.ping_ip_203
- entity: binary_sensor.ping_ip_204
- entity: binary_sensor.ping_ip_205
- entity: binary_sensor.ping_ip_206
- entity: binary_sensor.ping_ip_207
- entity: binary_sensor.ping_ip_208
- entity: binary_sensor.ping_ip_209
- entity: binary_sensor.ping_ip_210
- entity: binary_sensor.ping_ip_211
- entity: binary_sensor.ping_ip_212
- entity: binary_sensor.ping_ip_213
- entity: binary_sensor.ping_ip_214
- entity: binary_sensor.ping_ip_215
- entity: binary_sensor.ping_ip_216
- entity: binary_sensor.ping_ip_217
- entity: binary_sensor.ping_ip_218
- entity: binary_sensor.ping_ip_219
- entity: binary_sensor.ping_ip_220
- entity: binary_sensor.ping_ip_221
- entity: binary_sensor.ping_ip_222
- entity: binary_sensor.ping_ip_223
- entity: binary_sensor.ping_ip_224
- entity: binary_sensor.ping_ip_225
- entity: binary_sensor.ping_ip_226
- entity: binary_sensor.ping_ip_227
- entity: binary_sensor.ping_ip_228
- entity: binary_sensor.ping_ip_229
- entity: binary_sensor.ping_ip_230
- entity: binary_sensor.ping_ip_231
- entity: binary_sensor.ping_ip_232
- entity: binary_sensor.ping_ip_233
- entity: binary_sensor.ping_ip_234
- entity: binary_sensor.ping_ip_235
- entity: binary_sensor.ping_ip_236
- entity: binary_sensor.ping_ip_237
- entity: binary_sensor.ping_ip_238
- entity: binary_sensor.ping_ip_239
- entity: binary_sensor.ping_ip_240
- entity: binary_sensor.ping_ip_241
- entity: binary_sensor.ping_ip_242
- entity: binary_sensor.ping_ip_243
- entity: binary_sensor.ping_ip_244
- entity: binary_sensor.ping_ip_245
- entity: binary_sensor.ping_ip_246
- entity: binary_sensor.ping_ip_247
- entity: binary_sensor.ping_ip_248
- entity: binary_sensor.ping_ip_249
- entity: binary_sensor.ping_ip_250
- entity: binary_sensor.ping_ip_251
- entity: binary_sensor.ping_ip_252
- entity: binary_sensor.ping_ip_253
- entity: binary_sensor.ping_ip_254
- entity: binary_sensor.ping_ip_255
hours_to_show: 24
refresh_interval: 0
It can be a connection status checker for all devices
Vandana
(Vandana Dass)
July 7, 2022, 4:16am
15
I have a wifi door sensor that is configured in tuya integration. But it’s not getting auto detected by local tuya integration and I am not able to integrate it manually via local tuya as well.
Please guide me, how can I integrate in local tuya integration.
Regards…
